LQ4 Multiple misfire
So I've got a bit of a puzzle going on here. The shop I had my truck tuned at had some problems during the tuning process and I'm not 100% sure they nailed down the problem. Don't get me wrong, it runs pretty well, but I had my brother check the pcm on his tech 2 yesterday and we found some codes that my torque app doesn't pick up. Emissions codes were showing, which I knew about but still tick me off. They should have been turned off by the tuner. Besides that I had an oil pressure code. Fine. I pulled the original sender for the idiot light and replaced it with a sender for my gauge.
Big problem here is that with the torque app I was seeing multiple misfire problems, but couldn't narrow it down more than that. The tech 2 lets you see which cylinders are missing and it turns out it was all of them. Huh, weird. Brand new plugs, brand new wires, coils are old but I doubt they're all bad right? Well it seemed like MAYBE cylinder 3 was having a few more misfires so we pulled the plug and swapped it. No change. Swapped plugs and wires a few times and still nothing. Drove it around with the tech 2 counting misfires and noticed the weirdest thing. Accelerating doesn't cause any misfires. Idling doesn't cause any misfires. Constant throttle doesn't, and neither does WOT. However the counter SKYROCKETS on almost all cylinders when you gently decel. If I take my foot off of the pedal completely, no problem, but if I ease off say from 50% throttle gradually to 10% I get all kinds of misfires. What the hell is going on? I thought it might be vacuum, but wouldn't I get more misfires when accelerating in that case, because it would pull more air? I have no idea at this point, but I did take a vid to show the counter, just can't get it up until later. Let me know if any of you guys have thoughts.
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
meowMEOWmeowMEOW
Re: LQ4 Multiple misfire
Is your tcc/brake switch hooked up correctly and adjusted?
First thought Cam and crank sensors are out of phase, recording false knock and throw multiple miss codes. or If its happening on decel, what I imagine happens is one of two things; the above issue is preventing lockup (or unlock, depending when it happens). This would present itself as shuddering on decel, followed by miss codes. If the tcc switch isn't adjusted, and your decelerating while locked up, this can also throw codes. One begets the other, same symptoms. Easy thing to do is verify the TCC/brake switch, then if its still an issue, there is a setting that can be changed in HPT. Basically, it will adjust the threshold for false knock to help ignore the cam. I forget the exact name, but I posted a thread about this a while back (and probably in my build) about how my tuner addressed the issue.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
CPS was actually my next thought, but I haven't had a chance to get a new one, or look at the reluctor wheel.
TCC switch is a relay I connected to the brake light so that when brake is applied the switch is flipped. I used a diagram on here to wire it I think... I know the relay works because I can hear it clicking when I touch the pedal, but I haven't checked with the tech 2 about whether that sees the lockup occurring. I think I tried a while back to get the truck up to speed, keep steady on the throttle and then hit the brake a bit to see if I could hear a change in the TC, but I don't remember if I heard anything or not. IIRC I didn't notice any difference, but I went with the RPM I was sitting at being pretty close to yours Brew and another member or two. How is the TCC switch adjusted? Don't have HPT still, but I can talk to my tuner if that seems to be it.
meowMEOWmeowMEOW
Well on mine, it uses the 90's style 4 post brake switch wired into the tcc wire, so if you hit the brakes it knows to unlock. I didn't use an additional relay that I recall, just the purple tcc wire and post #4 on the switch. The switch itself just has a threaded shaft and locknut like most of the stock ones did, just adjust it out until you don't have a ton of travel before it engages the pedal.
If you have the TechII, can't it show lockup? You should be able to get to about 47-49 and have o/d engage, and monitor if it actually is. On mine, lockup almost feels like another 1/2 gear.
Mine just has the original 1 post for the brake lights and I ran a relay from there. From what I remember the signal that the pcm is opposite what the switch puts out which is why the relay was needed. The brake switch is normally open and then closes and sends power to the lights when you depress it. The pcm wants to see power all the time and then none when the pedal is depressed. It seems a bit odd, but I didn't have any problems with the wiring itself.
I can use the tech 2 to see whether o/d is coming on or not, but it is my brother's from his dealership. He brought it over last night and took it back to work, but I think I can get him to bring it back again for this weekend. We didn't have much time last night so I was more interested in seeing if the misfires were from any particular cylinders.
If you think its the crank/cam are out of sync, you can do a crank position relearn with the Tech2, that would be an easy test. Its a little unnerving because you have to hit the fuel cut off in neutral, bit it only takes a few minutes to do the whole thing. Pretty sure you need some kind of switch that lets the PCM know what gear its in, so if you deleted the NSS switch from the transmission, it may not work. In that case, it can be turned off in the tune.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#7 | |
meowMEOWmeowMEOW
The pins on the 4post are correct afaik, with the rear set being the "make/brake" for the tcc. The front pair are N/C and the rear are N/O. Its $6, and a lot less work and wiring.
#8 | |||
Old member
Buy the 71 Chevy truck cruise switch it is exactly what is needed for the brake lights and computer lock up. It's what I have on mine.It has the correct 2 connections that the brake switch wiring will plug right up to on it and the other two connections you can run spade connectors to it.
here is the link I started a while back on the switch. ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=614263 ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 04-04-2014 at 04:16 AM. |
if i was getting misfires from a carb'd rig i'd look in the intake for oil. lots of vacuum when you decel can pull oil thru a pcv. had that happen.
you mentioned emissions stuff not getting turned off, did the tuner mess with the DFCO at all? just spitballin' |
Using the tech 2 I found out the brake switch is definitely working, but the TCC is not engaging. I'll have to see if it's a solenoid or the whole converter. The trans was bought on CL so you never know...
Didn't get a chance to do a crank relearn, but I'm going to try to take care of it this weekend. Still want to check on the intake as well.
![]() Join Date: Apr 2005
Some guys use a relay for the TCC if they are running LED brake lights. Here's a thread that discusses that:
http://67-72chevytrucks.com/vboard/s...d.php?t=604032
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
