Old 04-05-2014, 10:45 PM   #1
aotte1
How do you align lower Front control arm?
1986, C10 short bed truck.
I am getting ready to remove lower front control arm, but concerned how you position it front to back when reinstalling and tightening the u bolts. I do not see any aligning mechanism. Do you mark it current position on the rod before removal. This is my first experience with this type of lower control arm mounting.
Thanks for the help.
Les
aotte1 is offline   Reply With Quote
Old 04-05-2014, 10:48 PM   #2
67c10rustbuket
67c10rustbuket's Avatar
Re: How do you align lower Front control arm?
There is an alignment pin in the front u bolt saddle and a recess in the control arm shaft. No need to mark anything. If you replace the bushings or cross shafts make sure the recess is toward the front of the control arm when you put it back together.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 04-05-2014, 10:50 PM   #3
BMERDOC
BMERDOC's Avatar
When you take it apart you'll see an alignment pin on the rear of the crossmember and a spot in the cross shaft to line it up with. Easy peazy. Consider doing the Caster mod before you reassemble it.
http://67-72chevytrucks.com/vboard/s...d.php?t=501241
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 04-05-2014, 10:50 PM   #4
BADAZ chevy guy
BADAZ chevy guy's Avatar
All the alignment is in the upper control arm via shims.
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline   Reply With Quote
Old 04-05-2014, 11:38 PM   #5
67c10rustbuket
here are a couple pics, should help give you an idea of what keeps the lower A arms aligned. The locating pin is to the front of the truck.
Dan <---(my name)
Old 04-06-2014, 12:37 AM   #6
aotte1
Thanks everybody!
Now I can take it all apart tomorrow with confidence that I can get it back together correctly.
And/or a summary of available front suspension parts that improve it, during a basic rebuild. Thing like taller ball joints, etc.
Thanks,
Les
Old 04-06-2014, 12:39 AM   #7
aotte1
Bmerdoc,
Thanks for reference to the lower control arm mod.
Les
Old 10-25-2014, 11:39 PM   #8
SunflowersAndRust
Thumbs up Re: How do you align lower Front control arm?
I am so glad I found this thread.... I have been scratching my head for an hour. This forum rocks!
SunflowersAndRust is offline   Reply With Quote
Old 10-26-2014, 12:16 PM   #9
SCOTI
SCOTI's Avatar
Yes it does. One of the best on the web IMHO.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
