tranny question?
when i put my motor and tranny in, lost a lot of tranny fluid, i went to move it and wouldn't move, so checked it the dipstick read like none, so i went and put some in, barely read, ended up having to put almost a gallon in it, now its starting to read, how much tranny fluid will this thing hold??? i assume that the tq converter drained some??? i know its kinda a dumb question but when i put this thing in i lost ALOT of fluid
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck ![]() My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
![]() Join Date: Jan 2011
Re: tranny question?
They hold like 10 so keep adding till its happy.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
11 lol
Well you have added about 4 quarts so looks like you still have 7 to go. That should get it on the stick. I had to put close to 6 in mine.
Jimmy ![]() Thanks for your service
Now I think I got one quart too many...err! How do I get it out without dropping the pan?
And your welcome haha
Pull the dip stick tube out of it.
Jimmy
That easy? Holy cow
I have done it for other reasons and had it make a big mess so I know it will lower the fluid level.
Jimmy
another random question, i pulled my truck out and took it around the block for another test run after i filled the fluid and hooked up the tcc, shifts kinda weird, if i hook the tranny lines up wrong will it still move?
could it be because I'm running open manifolds right now? maybe its not shifting weird its just so freakin loud i can't tell
Until it is all done and setup its hard to tell what they are doing.
Jimmy
That's what I was thinking, but it's sooo loud hard to tell what it's doing
But if the tranny lines are in backwards will it still move and shift?
#15 |
meowMEOWmeowMEOW
Did u fill the convertor first, separately?
As for taking some out, my 80e has a drain plug thats a huge torx, like a T50. Shifting might feel weird for a couple reasons. With open headers, its possible your getting way out of wack 02 trims, and it might pull a bunch of timing (so everything feels weird). Also, shift firmness, tq management in the tune can affect the feel...so if you haven't done a road tune or at least acclimated to the feel, it can feel off. The first few days on my 4l80e were weird, since it was a fresh rebuild, fresh converter, and the fluid was about 40*. Once we had that figured out, we realized there was an issue with false knock causing lockup problems (weird shifting issue #2) On the free-n-easy side, check the connections at the side of the trans and make sure they don't have any fluid on them etc, and that they are fully plugged in with a clean connections. Its also a good idea to double check wiring and lines/piping once you've had it warmed up a bit. Sometimes vibrations and heat can move,sag,melt, or pinch wiring that looked good when it was static.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#16 | |
#17 |
and another random question (didnt want to make a new thread) but the rubber hoses that come out the back of the trans, what are those for? do they need to be hooked up to anything??
#18 |
meowMEOWmeowMEOW
[QUOTE=dman1982;6624721]and another random question (didnt want to make a new thread) but the rubber hoses that come out the back of the trans, what are those for? do they need to be hooked up to anything??
I always forget, are you 60e or 80e? If its just the one rubber hose off a nipple towards the top of the case, its just a puke-hose for moisture.
#19 |
and that electrical connector on the drivers side, i need to put that on the correct way...how the heck do you do it??? I've been searching youtube and found nothing
#20 |
Are you talking about the big one that goes on the black shifter module ? I just took off my harness and I thought it could go in only one way.
Trying to get thru my LS swap ![]() |
#21 |
thats the one man, but it has a locking mechanism in it and can't figure it out, i was told how to do it but its not going all the way in
#22 |
i just figured it out
#23 |
#24 |
How did you do it? i can only get mine half way in as well
#25 |
I got the 60, and there is two
