8 lug wheel options
I have the longhorn cst (c20) and it's an 8 lug. I've had a heck of a time finding good wheels. I see endless posts for Dodge, Ford, and duramax diesel wheels. They have the same bolt pattern, but is the offset, and hub size going to work?
Re: 8 lug wheel options
Hit up some of our rim vendors on here,I'm sure they can find you a set of aftermarket wheels for it.
I just got a killer deal on a set of wheels that came off of an 08 duramax. I hope they work.
You need to watch I believe it was in 08 that GM changes bolt patterns. On there 8 bolt trucks
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Bought them today, will post my findings
#6 | |
Charlie Daniels w/ a Tq Wrench
The dually hub that white dog mentioned would narrow it a couple inches per side.
As far as those tires go, if the wheel is really 11" wide, there are not many more narrower or shorter options, especially not ones that are rated for a 3/4 ton truck. You are going to be MUCH better off reselling the wheels and looking for a new set.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
So as far as the dually hub goes, what would I be looking at for brakes?
I'm not familiar with the Eatons from the 70's. So I don't really know what they used for brakes. I'm thinking you have drums mounted to the rear of the Hub?
You may try to go with a hat style drum. 14 Bolt would be another place to look. GM had a number of different drums. Look for the 13" drums from late 80's early 90's G30 vans. Another option is to go disc. There are kits out there that use Cadilac or K20 calipers. Then there is factory style disc, from what I found out, isn't all that expensive to do. I robbed a setup off of a 03 van, but the OEM setup from a 99 and newer truck isn't all that expensive. |
They look cool. I know they switched recently. Good luck!
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
So the bolt pattern and hub size is correct, but the tire rubs on the front of the bed fender, and they stick out an inch (offset)
A smaller profile tire would fix the rubbing, but how can I Bring them into the fender so I can tuck them when I lower it? |
Here is some pics.
Never Ending Projects
You can't. The wheels would need to be narrower or have more positive offset.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
What is the narrowest tire that will fit an 11in wide wheel. It has 335/50/22 now.
I'm going to suggest a dually style hub for the rear. Can't help you on the front.
A 14 bolt dually hub will work also, but will need to have to be machined for the Eaton outer bearing. Then of course you'll have to get creative with your brakes. |
#15 |
How about narrowing the rear end a few inches?
#16 |
My thoughts as well. I'll be doing a bit of fabbing to lower it anyway. Problem is, I have never done it and am not sure I even have the tools to do so.
#17 |
You probably want a shop to do it. It has to be straight or you will ruin gears and bearings.
#18 |
OK, what kinda shop? And what does a guy pay for a narrowing these days?
#19 |
I will likely be cheaper to sell off these wheels and buy another set that fix correctly then to have a shop narrow the rear end. My guess based on what I have heard is, shop is going to run you $800-$1000
#20 |
Jeeeze...
