Old 04-13-2014, 03:17 AM   #1
cjlloyd81
cjlloyd81's Avatar
Suspension stuff...
Ok so I'm not getting where I had expected to. Last time I looked at upgrading my suspension I had a Z-28 and there were literally thousands of options. The only options I'm getting for my 86 GMC C3500 are Energy Suspension body mounts, leaf spring bushings, rear sway bar, tie rod end dust covers, and engine/trans mounts?? Does no one make full poly bushing/mount kits for these trucks?
Ideally I'm looking for poly bushings for both sway bars, rear springs, upper/lower control arms, coil spring mount/plate?, engine/trans mounts, carrier bearing?, etc... And I'd love to upgrade to tubular upper and lower control arms except the only options I've found for lowers are 2-4" drops. IMO my truck sits to low as is and I do NOT want to lower it anymore.
Has anyone else gone down this road? Any links if you have, or ideas if you haven't?
Thanks,
-Chris
1966 Dorsett Daytona - 16'6" Fiberglass boat "Suits Us"
1972 Chevrolet P30 Motorhome - "Giddy Up Go"
1986 GMC C3500 High Sierra Custom - "Ruby"
2007 Chevrolet Avalanche - "Faith"
cjlloyd81 is offline   Reply With Quote
Old 04-13-2014, 06:51 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Suspension stuff...
I just went to Summit and looked up all of the Energy Suspension line for an 86 C3500
They have the engine and trans mounts, cab mounts, sway bar bushings, tie rod boots and leaf spring bushings.
Your truck doesn't use rubber or urethane on the control arms. They are steel, therefore not applicable. There is no coil spring plate or mount on these trucks, so again, not applicable.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-13-2014, 09:56 AM   #3
bdiamond
Heres a link to the Energy Suspension catalog http://energysuspension.com/
bdiamond is offline   Reply With Quote
Old 04-13-2014, 10:05 AM   #4
1968vetL-71
Junior Member
1968vetL-71's Avatar
I know there will be completely different opinions on this but I've built/lifted/restored quite a few different crew cabs (73 up to 2000 style) and the couple times I've put anything other than OEM rubber body mounts in they absolutely brought out every rattle, squeak, shimmy, shake and the ride quality was junk. I know poly stuff has there place and I use them in some suspension stuff but for replacing body mounts, never again! It's got to have some cushion and give.
Again, there are people that I'm sure swear that it never changes, probably rides better than rubber, but just wanted to throw that out there. I know this has been discussed before so if ya search the opinions will be shown.
Good luck with the project and enjoy the build!
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 04-13-2014, 06:40 PM   #5
cjlloyd81
cjlloyd81's Avatar
Granted I haven't gotten under the truck and looked (and i will here in a few)... but don't the upper and lower control arms mount via rubber bushing? Thats really what I was looking for was poly replacements for them, and tubular arms would be great for stability and handling.
Thanks for the info tho
-Chris
Old 04-13-2014, 07:32 PM   #6
Tom
driving is in my blood
Tom's Avatar
I put all poly suspension bushings on my old 79. It still rode awesome and I thought "all these anti-poly people are stupid". So I bought some poly cab mount bushings. Worst idea ever!!!
Old 04-13-2014, 06:45 PM   #7
Tx Firefighter
Your control arm bushings are steel, not rubber. If you want stability, you're not gonna beat them.
Old 04-13-2014, 06:46 PM   #8
cjlloyd81
cjlloyd81's Avatar
Ah. that would end the confusion about poly bushings then Thx Tx Firefighter!
Old 04-18-2014, 06:27 PM   #9
uteman1011
uteman1011's Avatar
So if you're using OEM style rubber where do you go for those? Is the dealer the only place? I've been searching the web and am only finding aftermarket Poly.
uteman1011 is offline   Reply With Quote
Old 04-19-2014, 02:49 PM   #10
donut
donut's Avatar
local auto parts store should have most, if not all the replacement rubber.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
