Old 04-13-2014, 08:04 PM   #1
BigSix
LMC Wiper Arms + Washer Fluid Reservoir Question
Would you folks suggest the LMC wiper arms or is there a better source? I have one good arm that has a wiper blade on it but passenger side has a bent arm that won't take a blade.
Also - next to my radiator is a small sorta cube shaped plastic container with a steel mount bracket...is this for washer fluid? There is no pump nearby so that may be missing. The bottle has gradients on the side that tell you how many pints (maybe quarts?) are in it. I can't tell if its an overflow bottle for the radiator or for washer fluid. Any pictures of how the washer fluid system is supposed to look would be awesome.
BigSix is offline   Reply With Quote
Old 04-13-2014, 08:16 PM   #2
tincan1966
tincan1966's Avatar
Re: LMC Wiper Arms + Washer Fluid Reservoir Question
Don't know anything about LMC wiper arms, but would assume they are the same foreign made things like most their other stuff.
That reservoir is for washer fluid. The washer pump, should be mounted directly on your wiper motor, under the dash. A hose would run from the reservoir to the pump, then two hoses go from the pump to the washer nozzles in the cowl.
tincan1966 is offline   Reply With Quote
