Trucks worth?
Ok, so today I looked at that Olds that I said I might consider buying, and I think it may be an option, so the next step in this for me would be to find what you guys think my truck is worth. some information: 68 K10 LWB frame transmission/suspension, '73 350 engine(runs well, uses oil), 67 cab and front end, rust issues: drivers side rocker is pretty well gone, floor panel is solid but may be fiberglass(never really investigated on this) various surface rust/paint bubbles, bed floor is pretty rusty(maybe a dozen small holes). new fluids all around except radiator, new goodyear wrangler duratrac 31/10.5/r15 tires with less than 500 miles, new brakes all around except drums, new alternator and battery, Fixed some shotty wiring under the hood, wiring under the dash is a decent rats nest, but with some searching you can find the wire you are looking for, manual steering(alot of play in gearbox, needs replacing), manual brakes, 4 speed manual, 4.11 gears, and finally, it needs a new rear wiring harness, there was a ground short in the sockets.
Austin 2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked) 2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l |
Re: Trucks worth
I would guess if I were to see this in my area with the common problems associated with these trucks I'd say about $2500-3000 give or take
Re: Trucks worth
Alright, Thanks for your input, although it has been a very fun truck I found an olds 442 convertible for sale, and since my father has a 442 convertible, I thought it would be cool to own two almost matching cars.
![]() Join Date: Oct 2013
Re: Trucks worth
use the craigslist search: zoomthelist.com or searchtempest.com to locate like trucks to help figure out value.
#5 | |
Re: Trucks worth
Re: Trucks worth?
Any other opinions?
![]() Join Date: Feb 2014
Re: Trucks worth?
Here are some local ones in South Dakota for some kind of reference
http://siouxfalls.craigslist.org/cto/4421300660.html http://siouxfalls.craigslist.org/cto/4375066366.html
Being self employed means nobody answers when I try to call in sick. ![]() |
