Old 04-15-2014, 11:38 PM   #1
doiton3
MCPV-1 adjustment issues
Anyone else had trouble with setting the MCPV-1?
I have a 1968 C10 short bed
350 th350
255-60-15 in front 275-60-15 in rear BFG radial T/A - new
Stock rear drum brakes 11"x2"
Front disk kit from CPP CP4CK-6
3" drop spindles in front 4 inch drop springs in the rear.
All new hard lines and rubber lines.
MCPV-1 master
I bench bled the master
Bled each wheel starting at the farthest away.
Tested and adjusted re-bled each wheel.
The MCPV-1 is adjusted
Full forward bias (Large hex full counter clockwise)
Small hex full clockwise then backed off a small fraction.
The rear brakes are still locking up way before the fronts do, any
suggestions?
If I set the small hex full clockwise the fronts will lockup.
doiton3 is offline   Reply With Quote
Old 05-03-2014, 11:23 PM   #2
doiton3
Re: MCPV-1 adjustment issues
Removed the front metering valve and re-bench bled the master, re-installed the metering valve and re-bled everything.
Rears still lock up with hard braking
For now I have set the small hex (pressure adjustment) to full clockwise, no rear pressure.
Maybe the master is bad, wish CPP had disassemble/rebuild instructions so I could feel more comfortable pulling the proportioning/pressure valve for inspection.
Old 06-04-2014, 10:44 PM   #3
doiton3
I beveled the leading and trailing edge of the rear brake shoes and now I can give the rear brake some pressure, they are useable.
I would not recommend this master cylinder for short beds with front disk and rear drum brakes, the rear pressure adjustment is too coarse.
Old 06-05-2014, 09:31 AM   #4
Lee H
Lee H's Avatar
What shape are your shoes in? I went though a similar issue a few years ago, after many frustrating hours, changing MC & PV, rear cylinders. I changed the seemingly good looking shoes with only a miles for a set of Wagner (riveted) shoes and that cured the problem.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 06-05-2014, 04:05 PM   #5
doiton3
Brand new shoes, wheel cylinders, springs and hoses.
