Old 04-16-2014, 08:32 AM   #1
hardwaycooke
hardwaycooke's Avatar
Coolant? Green, Orange, or yellow?
Old engine. New aluminum rad. Which color coolant
And what mix? I was told green and just use
Pure coolant, no water. What do y'all think?
And after I build it in a couple months, what
Then?
Thanks!
hardwaycooke is offline   Reply With Quote
Old 04-16-2014, 09:04 AM   #2
skorpioskorpio
Re: Coolant? Green, Orange, or yellow?
This subject has come up before, and the general consensus was Green stuff and that Orange stuff was the stuff of the devil. That said Green stuff should always be mixed half and half with water, perferably distilled water. It's sold concentrated (or is also available pre deluted 50/50). Straight coolant is far less effective than a 50/50 mix, it's the water that regulates the temperature and carries away the heat. The ethyl glycol just extends the standing and operating temperature of the water. The cooling system is based on the boiling point of pressurised water not the boiling point of the glycol.
skorpioskorpio is offline   Reply With Quote
Old 04-16-2014, 09:06 AM   #3
Lee H
Lee H's Avatar
Green, 50/50.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is online now   Reply With Quote
Old 04-16-2014, 09:10 AM   #4
Ridgeclimber
I don't think it matters what color the coolant is. Different manufactures have different colors. As long as it it extended life coolant, should be ok. If you dilute the coolant 50/50 with water you should be good for about -40 degrees Celsius. Or what I used is Evans waterless coolant. Put it in full strength. It does not ever go bad or need to be changed, does not expand when hot so no need for an expansion tank, will not boil and cools good. I am using a stock two core rad to cool my LS LQ9 6 liter with no over heating problems.
Ridgeclimber is offline   Reply With Quote
Old 04-16-2014, 06:04 PM   #5
mblackburnjr
collector of vintage rust
mblackburnjr's Avatar
Also keep in mind that dex-cool(orange), is acidic. Air pockets from low coolant levels will result in rust forming. It also doesnt mix with green and can sludge up.
mblackburnjr is offline   Reply With Quote
Old 04-16-2014, 07:11 PM   #6
Andy4639
Old member
Andy4639's Avatar
Wink Re: Coolant? Green, Orange, or yellow?
Well solid anti freeze isn't going to do you much good it will also freeze up if there is no water mixed with it. The newer model cars all use the orange stuff because of the Aluminum heads and radiators. Any vehicle that has 2 differant metals is going to see some form of build up if not taken care of thats just how life is.
If you want the best solution mix it 50/50 but never run it pure water are pure antifreeze, neither will work by themselves for long extended times.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 04-16-2014, 08:35 PM   #7
cool68
take into consideration what year motor you are using and what was used in it from factory.
cool68 is offline   Reply With Quote
Old 04-16-2014, 09:52 PM   #8
ClemsonChevy
8 vehicles only 4 that run
ClemsonChevy's Avatar
Prestone sells a yellow antifreeze that will mix with any color. you can get it straight or 50/50, but you always run it 50/50. If you mix orange dexcool with older green type antifreeze, It turns sludgy and blocks passages. Most autoparts stores have their own generic brand of the yellow type "mixes with any model, any year" antifreeze.
95 2500 350 w/ 3.73
72 GMC 1500 SWB stepside
65 Chevy C10 SWB stepside
72 Chevy C10 LWB fleetside
ClemsonChevy is offline   Reply With Quote
Old 04-18-2014, 11:54 PM   #9
68c10airstream
68c10airstream's Avatar
Hi hardwaycooke, google search "www.motor.com" and look in magazine articles, august 2004 for an article called "coolant confusion". As a past ase mechanic i thought i had a pretty good hold on the antifreeze situation until i read that article. Motor.com has all of the past articles available as PDF files and i made a thick book with all of the technical info i needed, real handy to pull out the book and take it to the vehicle and look at theory of operation, typical readings, etc. I probably invested $40.00 in a holder, paper, sleeves and some ink, or i think you could send it to a jump drive and take it to office max and they will print it in color for a fair price. Good luck, Brian Fuller
68c10airstream is offline   Reply With Quote
Old 04-19-2014, 12:46 PM   #10
C. M. Wolf
C. M. Wolf's Avatar
Ok... With any AL parts on these trucks, ya might wanna avoid any coolants w/ "Silicates" in them. & it can be a huge caution to mix the wrong coolants w/ each other...
I personally won't use any coolant with Silicone/Silicates in them as they'll eventually clog your cooling system. The old GM Blue with Glycerol used to be the best coolant on the market,(& one of the more expensive ones), but GM has since replaced this coolant for Dexcool,(orange), which I wouldn't even use in an engine I didn't like!
This site is a good read, lots of coolant info...
http://www.google.com/url?sa=t&rct=j...griUIIWssl3OlA
IHTH
Michael
C. M. Wolf is offline   Reply With Quote
