04-19-2014, 06:16 PM | #1 |
Trim removal.
My 71 has the upper and lower trim. I dislike the trim on my truck and want to remove it. My question is, how do I accomplish this without screwing up the paint or trim?
04-19-2014, 06:23 PM | #2 |
Re: Trim removal.
Have you seen this from Harbor Freight? http://www.harborfreight.com/5-piece...set-67021.html
1971 Bone Stock C10 project "Jake" 1997 Sierra SLT factory short bed "Silver Bullet" |
04-19-2014, 06:29 PM | #3 |
Re: Trim removal.
You are aware there are a lot of holes under that trim right?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
04-19-2014, 06:41 PM | #4 |
Re: Trim removal.
I de-trimmed my Jimmy, and had to fill 90 holes.
04-19-2014, 06:54 PM | #5 |
Moderator
Re: Trim removal.
If you have a 71 the upper bed trim is attached using stick-on clips. The majority of your other clips are screwed in and as other pointed out will leave behind a lot of holes to be filled in.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
04-19-2014, 07:44 PM | #6 |
Re: Trim removal.
Yes ive seen the trim removal sets. I dont have one yet but plan on getting one. I also know there are a LOT of holes under the trim, but im willing to fill them in. Is there any way to do it without the set or should I just wait till next weekend when I can get a trim removal set.
04-19-2014, 07:52 PM | #7 | |
Re: Trim removal.
project: "my happy mess" |
04-19-2014, 07:48 PM | #8 |
Moderator
Re: Trim removal.
Upper front fenders all use screw in clips.
04-19-2014, 07:51 PM | #9 |
Re: Trim removal.
How wide is the original lower molding... 5 inches?
04-19-2014, 07:52 PM | #10 |
Re: Trim removal.
Alright thanks, ill just wait till I get that set then and ill take off the rest of the trim.
04-19-2014, 08:02 PM | #11 |
Re: Trim removal.
Lower trim is 4". PO rattle canned it with orange and its peeling in places. Im planning on repainting it eventually. Until I repaint Ill just gray primer over the welded up holes.
04-19-2014, 08:31 PM | #12 |
Re: Trim removal.
Was going to suggest masking tape like I've used with a jiggler in the past, but if the paint is peeling it could do more harm than good.
04-19-2014, 09:33 PM | #13 |
Re: Trim removal.
Thanks tim! I feel like the paint would probably do okay with masking tape as long as I don't peel it off fast like a band aid.
Tags |
advice, removal, special tool, technique, trim moulding |
