Old 04-19-2014, 09:55 PM   #1
csfields
csfields's Avatar
Lower Radiator Hose...ARRRGGHH
I am rebuilding my truck which can be seen at the link below. I have a new 350SBC Crate motor with a long style water pump. I am using a 4 core radiator and have purchased all regular brackets, hardware etc. Upper hose, no issue. Lower hose has been a pain. I went a purchased a hose for a 71 Chevy truck and it wont fit. After going to some cruise this spring I have discovered that a "stock "radiator lower neck comes out and up at an angle and the radiator I have comes straight out. I am sure, or at least I hope that I am not the only one to have encountered this problem. Any ideal part number, ideas, or whatever would be great, short of telling me to purchase a new radiator.
Thanks,
Casey
71 Chevy C-10 SWB 350/400 PS, PB
The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045
The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699
csfields is offline   Reply With Quote
Old 04-19-2014, 10:12 PM   #2
Lee H
Lee H's Avatar
Re: Lower Radiator Hose...ARRRGGHH
Yep, it's a wicked bend. It will fit, you'll probably have to cut off several inches to get it to the right length.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 04-19-2014, 11:07 PM   #3
Hawghauler
Hawghauler's Avatar
You can take it to your local rad shop and have him shorten it and braze or solder an elbow onto it. Shouldn't cost that much.
If I have to be on 4 wheels, It has to be a classic Chevy
1967 c10 Longbed (Hawghauler/Icy weather transport)
2003 BMW K1200GT (Rain bike)
2007 Softail Deuce (Sun bike)
2009 Ultra Classic Electra Glide (Everything else bike)
Hawghauler is offline   Reply With Quote
Old 04-20-2014, 12:13 AM   #4
Z10
Z10's Avatar
Sorry I don't have a pic, but I recently went through the same issues with my ZZ4. I finally found a bottom hose that would work. Try a AC 24053L. If I can remember to take a pic tomorrow I'll post a pic.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 04-20-2014, 09:24 PM   #5
Z10
Z10's Avatar
Here you go.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 04-21-2014, 05:36 AM   #6
gysgtc
Just ordered 24053L from Rock auto online. They have a close out on them. $13.50 shipped. I had the same problem with mine. I ended up having to cut the hose I had and use pipe in between. I hope this one works.
gysgtc is offline   Reply With Quote
Old 04-21-2014, 07:46 AM   #7
csfields
csfields's Avatar
Originally Posted by Z10 View Post
Here you go.
That looks like exactly what I need. I like how it rolls over the frame versus the stock one laying on the fram rail. I will try that one. Thanks a bunch.
I will let you all know how it works out.
Thanks,
Casey
Old 04-28-2014, 08:34 AM   #8
csfields
csfields's Avatar
Got the AC24053L off Ebay for 13 bucks. Did some small trimming and it fit perfectly. Thanks for the suggestion.
Thanks,
Casey
Old 04-28-2014, 09:46 AM   #9
Z10
Z10's Avatar
Glad it worked out for you.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 04-21-2014, 08:56 AM   #10
burnin oil
Could always stick a piece of an old hose under the new hose on the frame to keep it from rubbing. A short piece of pipe wont hurt either. Some trucks came from the factory this way.
burnin oil is offline   Reply With Quote
Old 04-21-2014, 10:02 AM   #11
Z10
Z10's Avatar
Glad I could help. You'll notice I did use some plastic corrugated pipe over the hose to protect it from rubbing on the frame. Hope it works for you guys.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 04-21-2014, 10:40 AM   #12
67 cst swb
67 cst swb's Avatar
I am guessing here... But I think that is a 73-newer Radiator.
If my memory is correct... They are the same dimensions but the lower hose connection is the difference.
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 04-21-2014, 10:58 AM   #13
sambudo
sambudo's Avatar
I also had the same issue, the rad in my truck was not stock. I ended up getting a reduced hose that fit tighter on the bottom. It worked out just fine.
I like the idea of having the rad shop ad an elbow to it. This might be a good solution also.
1968 C10, 250, L6 4spd OTF, Fleetside
Upgrades: Power Steering
.......................____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
sambudo is offline   Reply With Quote
Old 04-21-2014, 12:55 PM   #14
Z10
Z10's Avatar
I think you maybe correct. I just can't remember.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 07-31-2014, 08:00 AM   #15
JointTech
JointTech's Avatar
so its normal for the stock hose to be touching the frame? I dont like it. Im going to try the one above as well. I have a new alum rad but its the same as my old rad. mine has no up angle on the lower outlet.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 07-31-2014, 09:05 AM   #16
Steve Cole
I know this thread is a few months old but I searched Rock Auto, Napa, autozone, advance auto, and O'reilly auto parts for AC 24053L and no one had it. Any other suggestions where to get this hose? Thanks.
Nevermind...I found one.
Steve Cole is offline   Reply With Quote
Old 07-31-2014, 11:55 AM   #17
67 cst swb
67 cst swb's Avatar
Gates 20843
Goodyear 60855
My Trucks:
Old 07-31-2014, 03:28 PM   #18
Steve Cole
Gates 20843
Goodyear 60855
Hey 67 cst swb, are these Gates and Goodyear part numbers equivelants for the AC Delco Hose? (same size and shape direct replacement? or just other hoses that will also fit?) Thanks,
Old 08-01-2014, 12:04 PM   #19
67 cst swb
67 cst swb's Avatar
Yes, direct interchange from both respective websites.
It is simply the replacement lower hose for a 1973-1983 Chevy/GMC C10/C20/C30 2wd 350cid application
My Trucks:
Old 08-01-2014, 03:40 PM   #20
Steve Cole
Good to know, thanks!
Old 01-21-2016, 09:45 PM   #21
Ruscal
I also came to that later year hose as the best option. My engine sits 6" farther back and 1" lower, so I had to weld a longer outlet angled up to my aluminum rad. No rubbing anywhere.
Russ
RC
Ruscal is offline   Reply With Quote
Old 01-21-2016, 10:35 PM   #22
Ugly 61
The stock factory radiators for these trucks have the lower radiator hose connection angled so the lower hose will lay right on the frame rail. Stock 4 core radiators are hard to find I think they only came on trucks that had a big block and air conditioning.
Ugly 61
Ugly 61 is offline   Reply With Quote
Old 01-24-2016, 05:46 AM   #23
87Skier
87Skier's Avatar
I have an older 4 core radiator, don't know if its original, but its brass and it does have an angled neck. I bought the original radiator hose it lays directly above the frame rail and doesn't touch.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 01-24-2016, 08:24 AM   #24
72farmer
I am having issues with this also.I tried the Gates 20843 and the water pump end is too small and will not slip on.
72farmer is offline   Reply With Quote
Old 01-24-2016, 11:56 AM   #25
74baggedbug
I'm using the gates 20694 and it works perfectly.. When it's out of the truck it doesn't look like it will work but it does.. A local mechanic who restores 67-72 c-10's helped out when he saw I was running 2 hoses and a metal piece as my lower hose
74baggedbug is offline   Reply With Quote
