Old 04-21-2014, 10:22 PM   #1
HumphreyMurdoch
HumphreyMurdoch's Avatar
How to remove bed ends?
Hi guys, I'd like to remove the ends off my bed to see if they can be saved or just replace them. All I can see that bolts through is the chain for the tail gate and bolt the tail gate hinges on itself.
Any help, info or pics would be awesome. Thanks!
HumphreyMurdoch is offline   Reply With Quote
Old 04-21-2014, 10:28 PM   #2
pimpston65
pimpston65's Avatar
Re: How to remove bed ends?
i know on my stepside the box is welding by the tailgate hinge point ive seen some that are bolted, but not sure if theirs started out welded btw fleet or step
pimpston65 is offline   Reply With Quote
Old 04-21-2014, 10:31 PM   #3
HumphreyMurdoch
Oh good call, I neglected to mention it's a '62 Long Bed fleet side.
Old 04-22-2014, 07:43 AM   #4
Clyde65
Clyde65's Avatar
The fleets bed "ends" are not removable. You can get replacement panels for them but....You need to kind of piece it together, hopefully your a good welder.
I have a pickup bed trailer that had the lower part of the bed "end" rusted almost completely gone. I patched it at an angle right below the tail light socket.
Hoep this helps, show some pix of your challenge also, may help
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-23-2014, 03:36 AM   #5
natecr
http://www.customclassictrucks.com/t...a_patch_panel/
66' custom camper 327/3spd 3.5/5 drop 17"s
2013 Subaru STI stage 1, exhaust, springs, sways ect
2002 mustang Gt. Paxton novi 2000, caged, tubular everything, 441/409 hp/tq too much to list.
1994 dodge cummins, straight piped, nv4500 swapped/built too much to list.
natecr is offline   Reply With Quote
Old 04-23-2014, 09:45 AM   #6
lowlife4life
lowlife4life's Avatar
i just removed mine without cutting them into peices the joint where it meets the bedside is spot welded all the way up i used a putty knife to split the spots as for the rear you have to bend the small return where the tailgate joint is and it is also tacked all the way up its a pita but i got mine off all hammerred straight and back on you could never tell good luck
lowlife4life is offline   Reply With Quote
Old 04-23-2014, 09:51 AM   #7
lowlife4life
Here is what I used to break a lot of spots on my truck
Old 04-23-2014, 10:38 PM   #8
HumphreyMurdoch
Oh wow, that is awesome! Thank you guys!
'62 C10 LWB fleet side.
283 w/ a T5
Old 04-23-2014, 10:43 PM   #9
HumphreyMurdoch
Natecr, that article is exactly what I've been searching all over for.
Here's a couple pics of what I've got. You can't see the real problem because someone has covered it all up with bondo and its starting to rear its ugly head.
[IMG][/IMG]
[IMG][/IMG]
Both sides have bondo from the bottom to about the middle of the tail lights.
I hate bondo abuse
283 w/ a T5
Old 04-24-2014, 06:54 AM   #10
Vernski
Here is a link to Eastwood co. it's a abrasive blaster to get rid of the bondo but if you are replacing the whole end you may not need it. But here is the link anyway...Vernski
http://www.eastwood.com/eastwood-50l...e-blaster.html
Vernski is offline   Reply With Quote
