04-21-2014, 10:35 PM | #1 |
Hard to shift from park?!?
The steering column in my 70 is getting hard to shift from park. It was real bad this winter when it was cold but now that it is warming up it is still stiff. When you pull back on it so you can pull it down out of park it is really stiff and same to get back into park. Does anyone else have this problem and know a fix?
1970 SWB "old flame" 1967 SWB c10 sold 1972 Elcamino 496 2012 Denali HD dmax |
04-21-2014, 11:16 PM | #2 |
Re: Hard to shift from park?!?
I've had this problem too. Not sure if it's as bad as yours though. Mine would sometimes get stuck in the Park position, like going past park. Still works OK but could probably be rebuilt.
project: "my happy mess" |
04-21-2014, 11:35 PM | #3 |
Member #1049
More than likely its the 44 year old grease inside the shift collar starting to solidify. the quick fix is to spray some WD40 or liquid wrench down inside it just next to the shift lever and start working the lever back and forth, it should free up.
The correct fix would be to disassemble the turn signal housing and shift collar, clean out all the old grease and reassemble with new grease. |
04-21-2014, 11:58 PM | #4 |
thank you
04-22-2014, 09:05 AM | #5 |
Thank you LivRat, looks like I will have something to tinker with this weekend..
04-22-2014, 10:24 AM | #6 |
I sprayed some Silikroil on mine and it fixed it right up, sprayed into column and under hood.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives |
04-22-2014, 10:34 AM | #7 |
I've sprayed mine where the lever goes into the column before and it helped.
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
04-22-2014, 01:09 PM | #8 |
40 year old moving parts like cleaning and lubrication
10-31-2022, 01:02 PM | #9 |
This answer is yet another reason why I love this board.
After several weeks of increasingly difficult shifting from park, I came across this page, sprayed a liberal amount of WD-40 into the shift lever hole, and voilą, problem solved. Gear selection has never been this effortless! Well done, lads!
========================================== Miles 1972 GMC Suburban K15 - Custom Deluxe |
10-31-2022, 02:22 PM | #10 |
Who Changed This?
Mine got like that but it turned out to be the roll pin the shift lever pivots on was falling out the bottom.
10-31-2022, 05:35 PM | #11 |
Just to clarify. Is it hard to get our of park but easy to get into park?
Or is it hard going in and out of park? How about once it is out of park, does it move freely?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-01-2022, 09:28 AM | #12 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
If the lube and adjustment dont seem to work, and the shifter lever on the transmission is hard to move or stuck. Drop the pan on the transmission and check the nut holding the Rooster Comb. I had one come loose and it jammed up in Park. I dropped the pan and retightened the 5/8 nut and all was good again...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
