Old 04-27-2014, 01:43 PM   #1
kreigjean
Serpentine Swap new A/C wiring help.
I swapped my 83 GMC belt to a 1992 4.3 v6 serpentine system. My truck came with a/c from the factory but the previous owner removed all the components. I have reinstalled all the components from the 92' Chevy but i have no idea where the wires from the compressor need to go. One wire is green and one is brown.Name:  2014-04-27_10-51-11_275.jpg
kreigjean is offline   Reply With Quote
Old 04-27-2014, 03:47 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Serpentine Swap new A/C wiring help.
Welcome to the site. A/C wiring is in series. Switch (cab) -> low pressure switch -> hi pressure switch -> compressor -> to good ground. My 83 has a green wire from the harness into the hi pressure switch. Find the wire that gets 12 volts when the A/C switch is on. The wiring needs to be in series. If refrigerant pressure is low or high, power is cut to save the compressor.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
