04-27-2014, 06:21 PM | #1 |
play in steering column shaft
installed one of the CPP cheap Chinese steering columns that takes a universal joint that connects to a collapsible shaft to the rag joint. I disconnected from the rag joint and I can feel a little bit of play in the rod. when I'm driving its pretty tight to the left so when I turn to the right seems to have a little bit of play all my parts are new in the front end new gearbox also any help would be appreciated.. 72 chevy
04-27-2014, 08:08 PM | #2 |
Re: play in steering column shaft
I'd send it back and get a good one. These cheap columns have plastic u joints that break on you, leaving you without any steering. If it's new enough, you may be able to get your money back. I just installed a van tilt in mine, it took very little modification and works like new. $40 on craigslist. Best upgrade yet, other than power discs.
Good luck and don't trust that column. They are banned in some countries because of these cheap u joints.
If I have to be on 4 wheels, It has to be a classic Chevy 1967 c10 Longbed (Hawghauler/Icy weather transport) 2003 BMW K1200GT (Rain bike) 2007 Softail Deuce (Sun bike) 2009 Ultra Classic Electra Glide (Everything else bike) |
04-27-2014, 08:11 PM | #3 |
thanks but that's not an option at this point. Its almost a year old. u joint is stainless steel
04-27-2014, 10:53 PM | #4 |
The joint that fails in those Chinese steering columns is the one that's up inside where the column tilts.
Scroll down to the 4th pic here --> http://www.nz-hotrod.com/vbulletin/s...945#post109945 |
04-27-2014, 09:55 PM | #5 |
Chance
Buy a rebuilt one from Les Boatright. He does great work and he is a board member.
1968 Chevrolet Stepside BB 396 w/TH400 1972 Chevrolet 3/4 Ton 4x4 BB 496 w/TH400 |
04-27-2014, 11:02 PM | #6 |
the tilt works fine it's the shaft that connects to the rag joint and steering column its a CPP adjustable shaft and seems to have just a little bit of play in it
04-27-2014, 11:15 PM | #7 |
I saw another thread on those Chinese steering columns not something I would take a chance on
some have a failure in a short amount of time
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
