04-28-2014, 01:41 PM | #1 |
Loves all GMC trucks
72 Cab for cuts
Im cutting this cab up for cuts. No rust above the windo thats visible or showing.
If you see something you need or need cut, let me know. There is rust halfway on the rocker in towards the undercab brace. The top WAS perfect until the wind last weekend blew this thing about 15 feet. Its going away after everything is removed or cut off it. |
05-01-2014, 02:58 AM | #2 |
Re: 72 Cab for cuts
i wouldn't mind getting the roof, but the shipping is going to kill it.
build thread - 1972 C/10 "Ethyl" 1974 C/10 " Paw Paw" C/10 Club Louisiana instagram - @esso_c10 @projectpawpaw |
05-01-2014, 12:41 PM | #3 |
Re: 72 Cab for cuts
Hi, I would be interested in the inner roof where the sun visor bolts on the drivers side. Say from the visor mount to the windshield, visor mount to the cab on the drivers side then 8 inches to the two sides? How much would you need for that section shipped to 77316?
Thanks Eddie |
05-01-2014, 01:00 PM | #4 | ||
Re: 72 Cab for cuts
Mike |
05-01-2014, 01:55 PM | #5 |
Re: 72 Cab for cuts
Hi, those dimensions should work except I need more than 1 inch past the visor mount (going towards the back window). If you could cut it about 3 inches past the visor mount (going towards the back window). Then about the same distance towards the passenger side from the visor mount that should work out just perfect. $25 plus shipping would work for me.
Thanks Eddie |
05-01-2014, 07:06 PM | #6 |
Re: 72 Cab for cuts
Pm sent on dash panel complete.
05-01-2014, 11:37 PM | #7 | |
Re: 72 Cab for cuts
So you want the entire piece across the top? I thought you only wanted the d/s... I'll cut the entire piece as described above but it will be very expensive to ship that entire piece. I was thinking you wanted the d/s cut at the rearview centerline. I'll cut it this weekend and get you a quote. returned your pm about the dash. I have several out there. Thanks guys! Mike |
05-02-2014, 08:04 AM | #8 | |
Re: 72 Cab for cuts
Thanks Eddie |
05-02-2014, 09:23 AM | #9 | |
Re: 72 Cab for cuts
If you need more its fine just let me know! Mike |
05-02-2014, 09:36 AM | #10 |
Re: 72 Cab for cuts
05-02-2014, 09:57 AM | #11 |
Re: 72 Cab for cuts
Hello.
My truck has radio opening that was widened. Would like to patch in to correct. How much for radio area (apprx. 4"H x 11" wide) to 44041? |
05-05-2014, 09:35 AM | #12 |
Re: 72 Cab for cuts
Hi, if it helps with the shipping coast, If you just cut about 4 inches from the center of the visor mount all the way around, that should take care of what I need to repair.
Thanks Eddie |
05-05-2014, 10:46 AM | #13 | |
Re: 72 Cab for cuts
My plan is to cut the inner roof from door jam to door jam 4" past the visor and uo to the windshield. I will cut that piece in half at the rear view mirror area. It does not weigh much but will be in a pretty long box. Ill get it cut tonight and ready to mail out tomorrow. I was a busy guy this weekend so i appologize for the delay. Mike |
05-30-2014, 12:16 AM | #14 |
Re: 72 Cab for cuts
Do you still have pieces available from this cab. I need the lower windshield pillar passenger side.
05-30-2014, 01:22 AM | #15 |
Re: 72 Cab for cuts
How is firewall section where it meets the hood where wire harness lays
05-30-2014, 07:19 AM | #16 |
Re: 72 Cab for cuts
This cab is gone but I have a 68 cab out there I could maybe cut if there is interest.
Mike |
05-30-2014, 08:33 AM | #17 |
Re: 72 Cab for cuts
I'd be interested in the passenger side windshield pillar if it's clean. I can get a pic of the areas I need if you want.
05-30-2014, 02:54 PM | #18 |
Re: 72 Cab for cuts
All,
Ill post some pics tonight of the cab. Im mowing tonight so it will be around 830-900 before I can ge the pics loaded. V/R, Mike |
06-01-2014, 01:26 AM | #19 |
Re: 72 Cab for cuts
I'm closing a deal on several trucks but here is a pic of the wire run area. Rust on the pass side.
Mike |
