04-28-2014, 04:17 PM | #1 |
To Seal Or Not To Seal
I installed my windshield and the question is should I run a bead of sealer under the outside rubber or not to prevent a leak. If the answer is yes, whaat should I use? How about the back window?
1953 Chevy 3 Window Truck 3100 Series |
04-28-2014, 05:26 PM | #2 |
Re: To Seal Or Not To Seal
while my truk is a 58, there was no sealer in the windshield or back window and i did not add any except in one corner where i thought it might leak. have had no leakage around the windshield at all.
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
04-28-2014, 05:39 PM | #3 |
Thanks. I guess the thing to do is try it without sealer first and go from there.
04-28-2014, 09:17 PM | #4 | |
Let's check in later, after a good rainy drive.
Jimi J from I-Oh-Way '57 Panel 3105 Met this deer... Roof Swap on my Panel Jim's Bread Truck |
04-29-2014, 02:57 AM | #5 |
I did not use any sealant on my front windshield at first, but found it did leak at the bottom corners when it rained real hard. I got a tube of clear silicone at Home Depot. I simply pushed the nose of the tube down in between the rubber and the glass (and then between the rubber and the cab) while squeezing out the silicone. Very fast and easy. I did not need to seal the back window.
04-30-2014, 10:02 AM | #6 |
Or you could take it to the local windshield glass shop and talk then into sealing it for you using their nifty tool and sealer.
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
