05-01-2014, 02:09 PM | #1 |
Will a Later model (72 ish) Master Cylinder fit 64??
im having to redo all the brake lines on Ol'Blue. They are all beyond shot out. completely rusted thru in some parts. I feel like the master that i had in my 72 would fit. Has anyone does this?.
i would be going from a single to double port. Decent prices on these. Might as well upgrade as i replace a little bit. Thoughts?? Has anyone done this?? |
05-01-2014, 03:01 PM | #2 |
Re: Will a Later model (72 ish) Master Cylinder fit 64??
I don't know about fit, but the master you have a pic of is a disc/drum master and won't work correctly on a truck with drum brakes all around, you need a drum/drum mater where the two chambers are the same size. It has the correct residual pressure valves needed for drum brakes.
1964 C/10 Longbed Fleetside, base model. (build thread) (pictures) SOLD 1964 C/10 Shortbed Fleetside, Deluxe. (pictures) SOLD |
05-01-2014, 03:15 PM | #3 |
Never Ending Projects
If you still have drums all around, you could use a '67-'70 MC as they were still drum brakes but had the dual reservoir.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
05-01-2014, 03:46 PM | #4 | |
i assumed the one form 72 wouldnt work because of the discs, but i had a feeling there was some knowledge out there to point me in the rite direction. thanks fellas. |
05-01-2014, 03:49 PM | #5 |
looks about rite... thoughts? |
05-01-2014, 05:35 PM | #6 |
brake booster and MC mounted in engine bay
NOTE : any photos of the engine bay of my truck on my site there, has that same setup.... -W |
05-01-2014, 07:00 PM | #7 |
I've done what your gonna do. Made my 4 wheel drum setup work well. The truck will lay rubber better with the brakes than the motor. I used a new '69 m.c. and got the metal lines from the junk yard.
05-02-2014, 12:25 AM | #8 |
GREAT! thanks everyone, no power brakes on this things. Keeping it all crusty, dusty "the way it was" with a just a little touch of safety here an there ;-) thanks again.
05-04-2014, 10:57 AM | #9 |
did it on mine, got it at o'reillys. works great
05-02-2014, 12:22 AM | #10 |
60-66 Nut
Yep, I always recommend the '67-'70 master for drum/drum brakes whether manual or power.
