whitewall paint or dressing
I have some wide whitewalls on my '52 ride. The tires are in good shape, but there are a few minor stains and marks on the whitewalls. Is there a whitewall paint or dressing that works well to improve the looks? Where is it available?
Thanks ahead of time, daveboy |
Re: whitewall paint or dressing
Westley's BleachWhite is the preferred solution, I believe.
I have also had some success with small, localized touchups by putting a little laquer thinner on a piece of paper towell and working the problem spot. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Whammo from Car Brite is the best I've ever used to clean white walls. Not cheap, but worth it if you can get it. I've also used Mean Green from Dollar General with a lot of success. It's much cheaper and you can use it to degrease just about anything.
Just because you can, doesn't necessarily mean you should. 1959 3100 stepside 355 + T5 |
