14 Bolt Clicking Sound?
I've got a 1977 K10 lifted 8" with a full floating 14 bolt rear end out of a 79 K20. ORD disc brake kit, 4.10 gears and pretty sure it has a factory posi. Tires are 36x14.5 TSL Radials. The rear end started making a clicking, almost creaking, noise that I'm almost positive is coming from the driver side wheel area. Had the truck on the road for about 6 months and the sound just started a few days ago.
The sound is there even at very low speeds and only comes in when the truck is on the ground. I jacked up the rear end and spun it around. The wheel bearing feels solid as a rock. I just backed of the wheel bearing nuts and retorqued both of them and the noise is still there. Has anybody else run into this problem? I'm about out of ideas and these little noises drive me nuts worse than the white house. Ant helpful input would be much appreciated. Thanks guys.
1977 K10 Silverado "The Heavy Chevy" - 350/350/203...Version 2.0 in progress: http://67-72chevytrucks.com/vboard/s...d.php?t=576865 1972 C10 Cheyenne "The Brown Bomber" - 307/SM465/12 bolt posi...Plans for 2.5/4" drop 1992 F-150 "The Dooley" - 351C/M715 axles/six 44" Swampers...BOSS 351 stroker pending |
Re: 14 Bolt Clicking Sound?
My bearings were making that noise before I replaced the rear end. Look for metal shavings or something resembling anti seize compound in the diff when you take off the cover.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
