Old 05-05-2014, 03:28 PM   #1
TexasLS1
TexasLS1's Avatar
Control Arm Shafts?
I'm in the process of acquiring and prepping parts for a drop on my truck, and plan to replace ball joints, tie rods, etc. Is it necessary to replace the upper and/or control arm shafts, or can I just clean them up and paint them as long as they are in good condition?
TexasLS1 is offline   Reply With Quote
Old 05-06-2014, 06:52 AM   #2
PGSigns
PGSigns's Avatar
Re: Control Arm Shafts?
Clean up and paint is fine on those if they are in good shape.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-07-2014, 08:42 AM   #3
aotte1
Agree with previous poster Jimmy, I reused mine. Picture of cleaned-up shafts, from 1986, C10.
One other note, FYI, Moog makes offset upper control arms shafts, to help alignment if your truck has seen hard use during its life, and the front crossmember is sagging a little. They help by moving the upper control arm shaft out a little to compensate for crossmember sagging. They would be available if issue arises when getting alignment after all back together.
Les
aotte1 is offline   Reply With Quote
Old 05-07-2014, 10:02 AM   #4
TexasLS1
TexasLS1's Avatar
Awesome, thanks for the responses guys. I'll plan to blast and paint them. I figured there wouldn't be a need to replace them unless there was some odd wear on the bushing ends. Thanks for the alignment tip as well!
