05-06-2014, 03:57 PM | #1 |
4.6L Swap Opinions
Hey guys, I want to swap out my old 350 for something more fuel efficient and still a v8. I know 4.8 and 5.3 swaps are popular, but would it be possible to do a 4.6L Ford swap. I do understand this is sacrilege.
05-06-2014, 04:58 PM | #2 |
Re: 4.6L Swap Opinions
So much so that you'll be banned.
I think it'd be more trouble than it's worth. A 4.8/4L60E would be easier, and still get you 20 mpg. These trucks absolutely will not get more than 30 mpg, mainly because of the aerodynamics..
71 K20 64 GMC mud truck |
07-12-2017, 07:51 PM | #3 | |
1970 GMC 2500 700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles. 350 SBC 300hp Weiand Supercharger FiTech 30004 EFI |
05-06-2014, 05:10 PM | #4 |
Swapping a Ford motor into one of these trucks,That's just wrong???? on so many levels. I think it may even be against the law. If not, then it should be.
"Negative people always seem to have a problem for every solution" |
05-06-2014, 09:28 PM | #5 | |
Member #1049
I do not think it is sacrilege, its thinking "out of the box" I say if you have a wrecked Mustang/Crown Vic/Lincoln laying around and a Chevy truck with engine issues.. Go for it.. |
05-06-2014, 05:22 PM | #6 |
if you are doing this because you a 4.6 laying around, i would sell it and get a 5.3 or try to swap it for a chevy motor
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
05-06-2014, 09:31 PM | #7 |
You will spend more adapting it. One should only adapt a F*** into a Chevy if it's over 700 HP and free. Otherwise, I believe it's 50 state illegal with up to a ten year prison sentence. I could be wrong on that last part.
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
05-07-2014, 12:22 AM | #8 |
I wouldn't do it. The swap will be a can of worms, take a look at where the oil filter is on a 4.6, measure how wide it is, and take a close look at how the accessories mount. Sure, with enough money it could be done, but it won't be easy and it won't be cheap. You will have to use a Ford transmission, and that will present even more problems. 4.6's are pretty easy on gas, but they are not very powerful. And if that's not enough, the truck will probably be worth less when you are through than it is now.
If you are looking for fuel economy, one swap that I have seen done that is easy and won't destroy the truck in the process is a Chevy 4.3L V-6. If you can find a 4.3 with a Turbo 700/4L60 it's almost a bolt-in and will have good power and economy.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
05-07-2014, 09:01 AM | #9 |
I just want to throw this out there for fuel economy. I have a 4.6 and a 5spd in my Mustang. Avg MPG is around 18. 5.4 and Auto in my Expedition. Avg MPG is 14.1. My C10 weighs somewhere in between the two, I'm guessing that your fuel mileage will suffer tremendously. On the bright side, however, there's very few things out there that rival the sound of a nicely tuned Mustang engine....
LOVE my C10 though. I'd personally say that it won't be worth the headache. Even after you master all the fuel injection, have a new tank and pump, Fab some engine mounts, find a good tranny, strong enough for the truck, re-gear the rear end to match, connect all the electronics for the dash to the ECU, you will have THOUSANDS invested in a project that won't net you any better fuel economy, and will be a LOT harder to sell if you ever decide to sell your truck. It's one thing to have a different SBC swapped in, there's a market for that. Once you drop in a 4.6, then you will lose about 80% of your market due to the "sacrilege" or because people will be afraid you didn't know what you were doing and cobbled it together. It takes a good bit of fab work and $$ to make ANY swap clean. Not saying that there haven't been some amazing swaps done out there that are super clean and done for pennies, but that isn't typical of what you see.
1955 Chevy 3100 Task Force Pro Street - Sold! 1957 Chevy 3100 Task Force "Rat Rod" a.k.a. SLOTH - Sold! 1971 C10 Longbed factory A/C all stock 350/350 1979 Jeep CJ7 - Build date on the day I was born! -Keeper 2004 Expedition - Family Hauler 2007 Accord - Wife's around towner; I have more but not enough lines to post them! |
05-07-2014, 11:05 AM | #10 | |
Like I said, I honestly think you'd be much happier with a 4.8. 5.3 gets about the same mileage as the 5.3, so the only real difference is the up front cost, but you've got tons more power with the 5.3. Just my 2c.
05-07-2014, 10:03 AM | #11 |
I agree with the others, if you have a 4.6 laying around sell it and get a 4.8 or 5.3. The swap parts are cheap and readily available. I am sure the go fast parts are cheaper also!
05-07-2014, 10:28 AM | #12 |
Definitely not a great idea. Too much work involved to make it fit, run right, and still get gas mileage.
At the end of the day you will have spent a ton of money to have a truck with near zero value because anybody who likes Chevy's will hate your truck.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
05-07-2014, 10:58 AM | #13 |
The biggest problem I can see from a technical standpoint is that 4.6s are HUGE. Somewhat larger than a big block Chevy externally because of the large heads. And as others have noted, the fuel economy probably wouldn't be spectacular. I'd only do this if you had a 4.6 laying around, lots of time and fabrication skills, and didn't worry about the truck's resale value (or planned to put in a more mainstream choice before selling it).
For an odd economy engine choice, how about a Trailblazer's 4.2 straight six?
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
05-07-2014, 11:03 AM | #14 |
chevys can go in ford to make fords better, but you cant put ford into chevy the car gods will burn you alive
05-07-2014, 11:09 AM | #15 |
The Ford motors are great,that's why most Mustang racers are swapping LS engines into their cars...Aside from the physical issues,isn't the PCM and programming not very user friendly,especially when compared to the GM PCM and software.
07-12-2017, 05:46 PM | #16 |
I like the out of the box thinking.
I'm putting a 4.6 4V in my 67 chevelle. So far it's been pretty damn simple. I'm using a cobra t56(it was purchased with a broken input shaft and counter shaft for cheap) and my goal is 8500rpm using mostly factory parts. The joy of the modulars is they share a lot of components with later engines, like boss rods, GT lash adjusters and followers, stock chains and gears, factory mk8 block and crank, factory aviator heads, etc. Hard to make an LS rev that high with stock heads. Motor mounts are easy, mount a stock mount to a plateon each side and position it in the right spot. Hardest part will be headers, but I'm sure something will work. Pretty excited about the project honestly. Hopefully your project works out! Posted via Mobile Device |
07-15-2017, 11:48 PM | #17 | |
I agree with most of the others - it's your truck, so if you have a lot of time to invest in making it work and really want to do it, go for it. But selling it in the future might be tricky.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
07-16-2017, 04:52 PM | #18 | |
Local Detroit diesel nut!
Case in point, friend of mine had a '69 AMC AMX with a EFI Ford 5 litre out of a Mustang. Most people, including car guys, thought he converted the original AMC over to EFI when they looked at it. He didn't tell them any differently. When he sold the car the buyer could of cared less if it had a Ford engine in it, as long as it ran good!!! Mike
Nothing cool anymore, I am old and boring.... |
07-12-2017, 05:55 PM | #19 |
I feel dirty just reading this !!
07-12-2017, 06:49 PM | #20 |
Personally I would not but hey there's tons of gm products running ford engines,the LS is based off a ford engine so really what's the difference
07-12-2017, 07:17 PM | #21 |
Keepin an eye out
Dont do it.
On a side note, member here 70Blackfish has a late Dodge hemi in his truck.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
07-12-2017, 07:41 PM | #22 |
laying low
I know where you can get a fender to match.
07-15-2017, 10:35 PM | #23 |
The way I look at it, if your name is on the title, you can put any powerplant in the truck that you want. Keep in mind the 4.6 is fairly wide and pretty gutless unless you wind them up. Wiring them in is the same as any other EFI engine swap. Computers can be tuned with SCT or HPTuners depending on the year of the PCM and engine. I swapped a 2005 SOHC 4.6 in my '75 F100 and the truck gets 20-21 MPG all day long and it runs like a million bucks. Yah, it's a bit underpowered but better than the original 300-6 that was in it. I would say go for it if you have a 4.6 lying around, just don't open the hood and no one will ever know!!!
Mike
07-16-2017, 08:34 PM | #24 |
You get better power and low end grunt from a LS, even a 4.8. Packaging is easier with an LS. And as an added bonus, the spark plugs stay in on an LS until YOU choose to remove them. They also come out in one piece with an LS.
(Can you tell I've had issues with Ford Mod motors???)
2006 Sierra RCSB V6 5 Speed RWD. |
