Old 05-07-2014, 08:09 PM   #1
88Ironduke
Front sway bar question
I'm adding a stock front sway bar to my 72' C-10. I have the sway bar and brackets but not the straps that bolt up the lower control arms. Does any one have a part number for the bushing kit to mount to the lower control arms? Thanks in advance.
88Ironduke
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!!
My Build Thread: Project 72' Green
http://67-72chevytrucks.com/vboard/s...d.php?t=587932
88Ironduke is offline   Reply With Quote
Old 05-07-2014, 08:14 PM   #2
bigmac73
bigmac73's Avatar
Re: Front sway bar question
you need to measure the diameter of the bar, then you can order the bushings with the straps from amazon or i got mine at auto zone they had them in stock in the performance section my sway bar came off of a 82 chevy 1/2 ton (1 1/16 diameter)
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 05-07-2014, 08:23 PM   #3
DPowers
One foot in front of the other
DPowers's Avatar
Check here:
http://67-72chevytrucks.com/vboard/s...d.php?t=351586
http://67-72chevytrucks.com/vboard/s...ad.php?t=72338
DPowers is offline   Reply With Quote
