What bag system to go with ?????????????
I want to build my first 65 with bags front and rear. I think I am going to go the cheap easy way. clip and z the front. My question is what is the cheapest bag system that works, what size and brand of bags to use.
Re: What bag system to go with ?????????????
Are you trying to lay frame or not ?
Yes I want to lay the frame
There are a lot of ways to build your own suspension system, and the air management is really what will vary the pricing. Single or dual compressors? Manual valves or e-level? Individual valves or the VU4? Either way you go, I do suggest getting quality parts, because it will pay off in the long run and save you a lot of headaches.
As for bags, I would suggest the AirLift D2600 bags up front. You can use them in the rear, but all depends on how you will be setting that up. Some like to use the sleeve bag. |
Have you z a frame before?If not its a big job and has to be done right.
#6 | |
Cheap: Front and Rear Z with manual valves Easy: Front and Rear Porterbuilt/Scotts with a valve block.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
