Old 05-09-2014, 12:45 AM   #1
~DropShot~
~DropShot~'s Avatar
Airbag not centered on stock control arm
Hi all,
I just wanted to thank you all for posting great information that helps us guys that are new to restoring trucks.
I recently purchased a 67 bagged stepper and I have been able to find straight forward answers to certain projects on my truck. Doing a walk around my truck, one thing that concerns me is how my airbag sits on ride height on the front control arms. Its on stock control arms and I believe stock spindles. My lower control arm looks cupped at the bottom. When aired out the airbag looks centered when "pancaked" out. I was hoping you can evaluate my picture and possible give me advice on how normal or abnormal it looks. I've seen this curved airbags on only a few trucks out of many. In the future i plan on going Porterbuild all the was around but I wanted if it is something I can fix while keeping the coat reasonable.
Again thank you for any input!!
~DropShot~ is offline   Reply With Quote
Old 05-09-2014, 12:49 AM   #2
~DropShot~
~DropShot~'s Avatar
Re: Airbag not centered on stock control arm
My truck aired out..
Old 05-09-2014, 01:05 AM   #3
Hawghauler
Hawghauler's Avatar
I think usually you have a plate covering the top hole. It usually relocates the top of the bag. Then the bottom often has a piece of 6"(?) pipe filling the bottom bowl allowing the bag to completely flatten. I haven't installed mine yet, so I'm just pointing out what I've seen done in other builds. I'm sure someone with real experience here will enlighten you properly.
If I have to be on 4 wheels, It has to be a classic Chevy
1967 c10 Longbed (Hawghauler/Icy weather transport)
2003 BMW K1200GT (Rain bike)
2007 Softail Deuce (Sun bike)
2009 Ultra Classic Electra Glide (Everything else bike)
Hawghauler is offline   Reply With Quote
Old 05-09-2014, 01:06 AM   #4
Hawghauler
Hawghauler's Avatar
P.S. Your truck looks killer!
Old 05-09-2014, 01:17 AM   #5
~DropShot~
~DropShot~'s Avatar
Thank you sir! Yeah I'm trying to figure out if the PO installed the front bags as it should be.
Old 05-09-2014, 10:03 AM   #6
71tahoe
71tahoe's Avatar
Yep, it will do that just like a bendy straw. That brake line bracket probably needs to be attached somewhere and there is no steering stop I can see. Also, you probably need some lower bump stops unless there some internally in the bags.
71tahoe is offline   Reply With Quote
Old 05-09-2014, 03:23 PM   #7
TrkEnvy
The problem is your PO used the factory spring pocket without modifying the lca.. To fix it you can cut the lower control arm and weld in a drop brace at the correct angle to get the geometry correct or you can cut it off and modify your upper control arm to hold the bag..
1971 C10 - LWB shortened to SWB, welded in my C notch, reinforced trailing arms with 3/16 plate, new cpp 5" rear drop springs, 2" drop blocks, ece super panhard kit. Cpp drop spindles, 2 inch front springs, 5.3/4L80E
I call it Bruce Banner..
TrkEnvy is offline   Reply With Quote
Old 05-10-2014, 11:27 PM   #8
~DropShot~
~DropShot~'s Avatar
Thanks TrKEnvy, it makes sense what you're saying now that I'm looking at the picture. I would probably end up going that route, but would you recommend modified LCA that I can purchase?
Derrick
Old 05-10-2014, 11:22 PM   #9
~DropShot~
~DropShot~'s Avatar
Yes, there is definitely work that needs to be done, I just realized I was missing the lower bump stops until you pointed that out. I appreciate your input bud!
Derrick
Old 05-11-2014, 12:49 AM   #10
67ctener
67ctener's Avatar
Nothing wrong with your set up. Many people are running this common plates/cups and it is fine.
67ctener is offline   Reply With Quote
