Drum brake question
Was wondering if you could help, I used a rear diff from a 1990 2wd silverado that was narrowed and had new axles from Moser made but had them install 1/2" studs instead of the 14 mm to match my front rotors (72 c10). The center hole around the hub is the same size but doesn't fit tight and the stud holes are obviously larger. I was wondering if the earlier drums from the mid 80's that had 1/2" studs would fit my application or did I screw myself
Re: Drum brake question
with the amount of torque you put on the wheel it wont matter that the drum hole is a tad bigger not enough to worry about 14mm and 1/2 is very very small diff your all good
How tight should the hub hole fit the hub stub? I have a little less than 1/16" play.
![]() Join Date: Jan 2011
The fit of the drum to the axle spud needs to be a close fit. That is what centers the drum. The fit on the studs can be a little loose.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
