Old 05-11-2014, 12:50 AM   #1
jamesjones
Freakin Awesome!
jamesjones's Avatar
I need some ID help
This came with the F-Body oil pan kit I got. I couldn't find anywhere it fit. Any ideas?
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 05-11-2014, 12:52 AM   #2
jamesjones
Freakin Awesome!
jamesjones's Avatar
Re: I need some ID help
Also, can you guys help me ID these sensors...
Old 05-11-2014, 12:57 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The first thing looks like a fuel tank lock ring....I had no such piece in my oil pan.
Then:
Coolant Temp
Cam angle and oil pressure
Evap
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-11-2014, 01:01 AM   #4
jamesjones
Freakin Awesome!
jamesjones's Avatar
Then:
Coolant Temp
Evap
Thanks man. Yeah, I was like WTF do I do with this thing? It came out of the same bag as all of the hardware for the windage tray.
I can just plug and delete the EVAP right?
Old 05-11-2014, 02:05 AM   #5
truckdude239
truckdude239's Avatar
Or just leave it it's normally closed u till power is sent to it
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 05-11-2014, 02:44 AM   #6
kevmac
kevmac's Avatar
water temp on the side of the head.
kevmac is offline   Reply With Quote
Old 05-11-2014, 05:42 PM   #7
Robznob11
Robznob11's Avatar
The second pic at the back of the manifold the one on the left is the oil press sensor(not needed) the right I'm not sure . The thing right behind the manifold is the purge valve for the fuel tank (not needed for a swap)
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 05-11-2014, 06:29 PM   #8
Bigdav160
Bigdav160's Avatar
The shim looks like a 8.5" axle pinion shim.
I don't know my LS's so I'm going to guess: temp sensor, knock sensor, CMP and finally evap purge solenoid.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 05-11-2014, 07:29 PM   #9
wgeyer88
1. No idea.
2. Water temp sensor.
3. Left: Oil pressure. Right: Crank position sensor.
4. Evap, or some other emissions related thing. Most people just leave it unplugged, the valve stays shut that way. You can completely remove it and plug the hole too.
Will
1970 CST10 SWB LQ4/4L80E
2004 Silverado (sold)
2007.5 Dodge Ram 2500
wgeyer88 is offline   Reply With Quote
Old 05-15-2014, 10:07 AM   #10
truckdude239
can u post a link to that?
David fuller
2000 Tahoe 5.3l 378
Old 05-15-2014, 10:21 AM   #11
jamesjones
Freakin Awesome!
jamesjones's Avatar
Here's the link...
http://www.ebay.com/itm/LS-LQ4-PURGE...62c578&vxp=mtr
Old 05-15-2014, 04:52 PM   #12
solidaxel
solidaxel's Avatar
Originally Posted by jamesjones View Post
Well there goes another ten bucks !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-15-2014, 07:34 PM   #13
jamesjones
Freakin Awesome!
jamesjones's Avatar
Lol, right?
Old 05-17-2014, 09:16 AM   #14
truckdude239
thats what i said
David fuller
2000 Tahoe 5.3l 378
Old 05-17-2014, 04:04 PM   #15
solidaxel
solidaxel's Avatar
10 - 4 !!!
LS 3 4L70E
Old 05-17-2014, 06:44 PM   #16
clinebarger
A word of caution on using rubber expansion plugs. If it were to come loose, The stud can fall into the intake....If it made it's way to a piston...Bad things will happen.
I had a customer bring a Duramax in for low power/black smoke, He had installed a rubber expansion plug where the silencer would go on the intake tube, The stud fell into the intake & destroyed the compressor wheel on the turbo.
clinebarger is offline   Reply With Quote
Old 05-17-2014, 10:20 PM   #17
Blackpony
Blackpony's Avatar
For the evap hole I just used a 1/4" npt tap and put a plug In there.
The first pic is for sure a pinion shim for probably an 8.5 rearend. The other pics are coolant temp and cam position and oil pressure switch.
Blackpony is offline   Reply With Quote
Old 05-15-2014, 07:44 AM   #18
jamesjones
Freakin Awesome!
jamesjones's Avatar
I got this little block off plate from ebay for the evap...
Old 05-15-2014, 10:00 AM   #19
wgeyer88
I like that idea! My evap doesn't seem like it will seal well with just the one bolt. It can wiggle around in the hole.
Will
Old 05-17-2014, 09:28 AM   #20
Robznob11
Robznob11's Avatar
if it matters now... lol! another option to the evap plate is a rubber oil plug found at oriles. it works just like a rubber freeze plug just smaller. that's what im running!
LED TAILS
Old 05-17-2014, 03:14 PM   #21
solidaxel
solidaxel's Avatar
What holds it in?
LS 3 4L70E
Old 05-17-2014, 03:58 PM   #22
Robznob11
Robznob11's Avatar
Talking Re: I need some ID help
It insertin the hole, it has a wing nut on top of it. The tighter you turn it the more the plug expands and the tighter it gets in the hole!
LED TAILS
