07-31-2003, 09:54 AM | #1 |
Get the gas outta my cab!
Anyone know of a good kit or junkyard plan to get the gas tank out of the cab? The whole tnak-in-the-cab concept just makes me nervous.
70 GMC, SWB, 2WD, low |
07-31-2003, 10:00 AM | #2 |
The best and only one I've heard of so far was getting a Blazer tank for between the frame rails in back.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
07-31-2003, 10:02 AM | #3 |
Not that I know of. I think the majority of the people here make there own setup. I know that using a blazer tank is common. I am going to make my own tank though.
Save your money and do it right the first time. 1968 GMC short bed 1972 Cab 74 SB Chevy running gear |
07-31-2003, 10:03 AM | #4 | |
Resident Curmudgeon
Course relocating it does allow for cab reconfiguration and stereo speak possibilities. To answer the question, a junkyard solution is a Blazer/Burb tank from same years. Direct bolt in, though it does hang low. All the parts vendors can offer aftermarket solutions as well.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
07-31-2003, 10:11 AM | #5 | |
No freight trains
07-31-2003, 10:16 AM | #6 |
Resident Curmudgeon
It's actually a little over 20 gallons full. If you relocate to the rear, you've got the "Pinto" factor to deal with too. I'm assuming the a-holes may also rear end ya too. These trucks were not engineered to 21st century safety standards. I agree the rear placement probably is better if its a real concern of yours, plus you get a lot more lef room too.
07-31-2003, 10:53 AM | #7 |
I am mainly doing mine for weight transfer and to get more room in the cab. It will make a cleaner looking interior IMO
I have the poly blazer tank to install...eventually.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
07-31-2003, 10:59 AM | #8 |
I agree with CPNE. If behind the seat tanks are a serious safety issue I think we all would have heard the horror stories by now. OK, so you got 20 or so gallons of gas sitting in the cab with you but IMO its a fairly safe place. There are only 2 contact "hit" points on either side and they are very narrow with a fair sized buffer zone between the tank and the cabsides. Think about the mid 80's Chev trucks with the side tanks. I think they recalled a bunch of those because there wasn't enough structure to protect the tank. You get T-boned and gas spillage is a sure thing. You'd have to get hit really, really hard to rupture a behind the seat tank. Just make sure your tank, filler neck and fuel lines are in good shape.
07-31-2003, 11:05 AM | #9 | |
Resident Curmudgeon
07-31-2003, 11:06 AM | #10 |
Resident Curmudgeon
Damn Southpa, someone agrees with me and we were typing about the same 73-up tank issue at the same time too. You need to get some rest, and perhaps consult a shrink.
07-31-2003, 11:24 AM | #11 |
Safety is not the only issue here. I am a big dude and want the space for me and my junk. The new weight distribution is an added bonus.
07-31-2003, 11:30 AM | #12 | |
Resident Curmudgeon
07-31-2003, 11:40 AM | #13 |
Mike
In the philadelphia inquirer,yesterday,there was an article about the side tanks.GM settleda class action suit for 495million a while back.It was disclosed on tuesday.Now some lawyers are saying this is showing others how much you can sue the auto makers for!
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
07-31-2003, 11:43 AM | #14 |
digger51,
For what its worth, If you are going to go through all the work necessary, (not Much really), to relocate to the rear, Do it right and get yourself a STEEL tank or at the very least aluminum. The Truck Shop has an awesome deal on every thing you would need in kit form. Just my .02 from experince with all three setups. Good luck. 72longbed |
08-01-2003, 01:31 AM | #15 | ||
Bloo
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
08-01-2003, 11:18 AM | #16 |
Old Skool Club
Why move the tank? Just to get rid of (1) the hole behind the door? I still have my original chrome gas cap....something that Classic Truck magazine says is "rare". (2) to get rid of the smell of gas? That is usually due to leaking, deteriorated gas hose from the filler neck to the tank. Replace it. (3) Weight transfer? (4) Safety?
I drive a school bus. After the tragic deaths of those folks in Ohio one year, school busses were modified to house the steel fuel tanks in a steel cage, to protect them from rupture upon impact. I had a Pinto, and the FoMoCo plan to "protect" the occupants was to place a thick polyethelene shield between the tank and the rear axle. It satisfied me, for the time, until I decided to put a set of Firestone 500's on it and live dangerously. I, too, thought about moving my tank. But, I've decided against it...unless, I decide to move it to put some honkin' speakers behind the seats. Now, that is a reason to move your gas tank!
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
08-01-2003, 03:50 PM | #17 |
Keep On Truckin'
My opinion is that the gas tank belongs between the frame rail and the drive shaft just like the late model trucks. That way the tank is out of the cab (no gas fumes for whatever reason, more room, etc), more desirable weight transfer, rear end collisions have less chance of rupturing the tank as do side impact collisions. As a side benefit this allows you to carry the spare tire where it belongs on a fleetside. I have not found anyone doing this yet but I haven't given up the idea. The fuel tank in my ’94 Mazda B2300 is almost what I need but not quite. I am pursuing the option of having one custom made of aluminum plate. I believe that over the last 30+ years automotive safety engineers have improved the placement of the gas tank to minimize injury. Think about it this way, if it was such a good idea to keep the tank in the cab or on the outside of the frame rail wouldn’t it still be done that way?
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
08-01-2003, 04:02 PM | #18 | |
Resident Curmudgeon
08-01-2003, 05:29 PM | #19 |
Keep On Truckin'
Can you say Crew Cab or Extended Cab?
Crew Cab and Extended cab; how did I do?
If I am not mistaken, I believe even crew cabs and extended cabs have a back glass and an area under the back glass; like say, a regular cab.
08-01-2003, 10:05 PM | #20 |
Resident Curmudgeon
mocwon, I wasn't trying to insult your intelligence, just trying to be funny. If you took it the wrong way I appologise.
Yes, all cab configurations come with a fixed back window and structure below it (except the Avalanche ). My point was that I don't believe that the removal of the tank from the cab was primarilly motivated by GM's concern for safety. I think the real motivation was design changes. Not only to make the new cab and body lines flow as drawn up, but also to facilitate the same changes that are used for reasons to remove it from our cabs - Extra leg room/ stowage, generally more freedom to reconfigure the ergonomics (a word probably not used too much back then). I agree, the resulting placement is a safer one and I'll also bet that the outside frame rail saddle tank was nixed because of some gov't safety regulation. Had GM been able to, they may have stuck with those saddle tanks rather than the inside frame rail design simply to cut costs. Sooo, back to my initial point (and I have nothing against relocating the tank), removing the tank simply as a safety precaution is just trading one potential hazard for another. However, if one feels safer, then in theory they are. Remeber the "duck and cover" drills in the 50's and 60's. They look absurd now, but by God you felt safe under your desk.
08-01-2003, 10:29 PM | #21 |
Could some of you that have pics post them so I can get an idea on where the filler neck could go & what it will look like.. I have a step side. Thanks
70 StepSide factory original for now 6 banger & all... |
08-01-2003, 11:02 PM | #22 |
Keep On Truckin'
Don't worry about it, no offense taken and no apology necessary.
Yes, I do recall the rather foolish duck and cover drills when I was in school. A few folks in the neighborhood even built fallout shelters, as if that would help. Oh well, so much for the good old cold war days. I am quite a ways away from even needing a gas tank so I will keep checking out different trucks to see if I can find the Holy Grail. If not, I guess I will just cough up the money for a design like I described.
