Old 05-13-2014, 12:11 PM   #1
Ricos54
Ricos54's Avatar
Inside dome light
Are any of you setting up a dome light to come on when you open the door like newer trucks do? How are you doing it and where did you buy it?
Ricos54 is offline   Reply With Quote
Old 05-13-2014, 02:28 PM   #2
youngrodder
youngrodder's Avatar
Re: Inside dome light
I used a stock dome light but I changed the guts out to LED. Looks like the old light on the outside but has modern lighting using an LED panel.
You can probably find the thread on it if you search by threads I have started if you are interested.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 05-13-2014, 03:32 PM   #3
OrrieG
OrrieG's Avatar
I kept the dome light and circuit stock. I added kick panel courtesy lights that are operated off of door switches using a relay set up for ground energizing. Look at this for how to make your dome work with the doors.
http://www.alanhorvath.com/54chevy/domelight_relay.php
Old 05-13-2014, 04:14 PM   #4
_Ogre
_Ogre's Avatar
check my build. i believe your hinges could use a similar bracket
no relays used. power to dome light, ground thru headlight switch or door switches
bracket. easy peasy 1x6x.125 steel with 2 holes
looking up to the hinge w door open
w door closed
shop air compressor timer
Old 05-20-2014, 12:37 AM   #5
OrrieG
OrrieG's Avatar
[QUOTE=_Ogre;6671936]check my build. i believe your hinges could use a similar bracket
I used the same bracket setup as Ogre, concealed and works great.
Old 05-18-2014, 07:03 PM   #6
oldman3
oldman3's Avatar
Hey Rico, couldn't get the pics you wanted to post on the PM, so I'm going to put them here, any questions let me know???...Jim
oldman3 is offline   Reply With Quote
Old 05-19-2014, 12:23 AM   #7
magicoolbus
magicoolbus's Avatar
If a standard door jam switch that was typically used on 68 and up trucks won't fit with out binding, try this switch (search 58-64 beetle). I used it on my burb 3rd door and the burb barn doors. Very cheap and works great. The ones in my bug have been working for over 50 years.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 05-20-2014, 12:29 AM   #8
magicoolbus
I got a couple of PM's of where to find the switch. Here's one of many on Ebay:
http://www.ebay.com/itm/VW-INTERIOR-...24d072&vxp=mtr
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
Old 05-21-2014, 02:08 PM   #9
_Ogre
_Ogre's Avatar
easy peasy
