Old 05-13-2014, 03:51 PM   #1
Rednek13x
Rednek13x's Avatar
are 3/4 ton truck frames bigger?
is this height bigger on 3/4ton trucks compared to the 1/2tons? If so and or what are the measurements of a half ton?
Rednek13x is offline   Reply With Quote
Old 05-13-2014, 04:00 PM   #2
_Ogre
_Ogre's Avatar
Re: are 3/4 ton truck frames bigger?
3200 (lwb 1/2 ton) and 3600 (lwb 3/4 ton) are the same frame. FAM sect 2 sheet 26.00
3800 1 ton has a heavier frame that goes straight over the rear axle
shop air compressor timer
Old 05-13-2014, 04:11 PM   #3
Rednek13x
Rednek13x's Avatar
do you know about a 3100 swb 1/2 ton?
Old 05-13-2014, 07:24 PM   #4
_Ogre
_Ogre's Avatar
it's longer
Old 05-13-2014, 07:39 PM   #5
OrrieG
OrrieG's Avatar
link in my signature sends you to a site with spec manuals for the different years. There is a frame section that gives the difference in width, depth and thickness of the frame channels. It also has wheelbase, track and other dimensions. The link lands on a 56 truck page, scroll down and click on the year index tab to get to the menu for different years.
Old 05-13-2014, 08:56 PM   #6
Rednek13x
Rednek13x's Avatar
thanks guys! exactly what i was looking for!
Old 05-13-2014, 09:08 PM   #7
mr48chev
mr48chev's Avatar
The big difference between a 3100 frame and a 3/4 ton frame besides length is that the 3/4 ton frames are pretty well straight all the way back from the cab mounts while a half ton frame be it short or long bed spreads out at the rear to 40 something (not taking the time to look it up or measure now) inches .
If you had a good 3/4 ton frame that you were thinking about shortening to put under a short bed the only big issue would be the width of the frame at the rear and needing a notch in the back if you decide to lower the truck any.
My ongoing truck projects:
Old 05-14-2014, 11:04 AM   #8
_Ogre
_Ogre's Avatar
not on tf trucks, the 3200 frame is the same as the 3600 frame, same as in same frame
3800 frame is straight over the rear axle
Old 05-13-2014, 09:22 PM   #9
Rednek13x
Rednek13x's Avatar
going to put my trans am clip on my frame and was just brain storming some things... It will stay a long bed for now. Big notch over the rear axle 4 link, bags.
Where do you think i would need a notch in the back if i decided to lower it?
Old 05-14-2014, 11:06 AM   #10
_Ogre
_Ogre's Avatar
usually the notch goes over the axle
Old 05-14-2014, 11:56 AM   #11
Rednek13x
Rednek13x's Avatar
LOL i know, i guess i was thinking there was somewhere else if i made it a short box, but i should be set now!
