05-14-2014, 09:54 AM | #1 |
Fuel Gauge hook up
Got some new factory replacements and need to know how to wire the fuel gauge, I have a wire coming from the sending unit (thats it have no clue as to where to go from there). Bought truck like this and I need some help) Ran out of gas twice now)....230 with granny 4 is terrible on gas......
Thanks |
05-14-2014, 10:12 AM | #2 |
Re: Fuel Gauge hook up
this should help.
Your sending unit wire will go the fuse box. On the back of the gauge.....pink on the right and tan on the left side of the gauge as your looking at the back of the cluster.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
05-14-2014, 10:35 AM | #3 |
05-14-2014, 11:27 AM | #4 |
No problem.....
05-15-2014, 10:29 AM | #5 |
mine is hooked up but it says i have a full tank when i only have a third of a tank? it use to not do that!!
05-15-2014, 08:19 PM | #6 | |
(1) Bad connection or broken wire somewhere between the gauge and sending unit. A quick way to test for this is to temporarily jumper the sending unit wire to ground. If that makes the gauge go to empty the wiring is okay. If not, check for bad connections or a break in the sending unit wire. (2) Poor ground connection at the sending unit. Check to make sure the ground wire has a good clean connection that's free of rust & paint build-up. (3) Failed sending unit. |
10-21-2014, 01:51 PM | #7 |
my gauge stock with new sending unit, the needle just barely moves from where you can't see it to just past empty toward the full side. the new sending unit ck ok with meter at 0-30 om. bad gauge? wires reversed on gauge?
1961 chevy K10 my build is------------61K10 build |
10-21-2014, 02:08 PM | #8 |
What happens when you ground the wire to the sending unit?
And what happens when you pull that wire off the sending unit? |
10-22-2014, 01:40 PM | #9 |
I replaced the gauge with one that came with the tk and it was working. still doesn't work. will do some more testing today.
10-22-2014, 02:24 PM | #10 |
Thanks for the diagram, mine bounces like a kangaroo on amphetamines! I used to live in Fayetteville, on Gruber Road!
1963 Chevrolet C-10 "Ginger" 1970 C-30 Dump Truck "Scarlet" 2019 Chevy Silverado 2500 Z71 LTZ 1947 Indian Chief Roadmaster with Sidecar. 2012 Indian Chief Serial #002 of 110 built in '12 2016 Indian Chief Roadmaster |
