Uppwe A/C mounts for LS
I am looking for some pics of upper A/C mounts.
I have Dirty Dingos and they will not fit in the area between the inner fender. I can not use a lower mount and I do not want to go with a whole new front runner system. This is on a 5.3 truck engine. We changed to a 2010 Camaro pump but that did not work out with alignment of crank shaft and power steering pump, so went back to the truck pump
Re: Uppwe A/C mounts for LS
Sorry that is the UPPER mounting bracket !!
Boosted Member
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#4 | |
The Holley bracket extends too far into the inner fender area of the 46 Chevy pick up just like the Dirty Dingo one we have, which will be up for auction as it will not fit this truck
Vintage Evil
I have this one:
http://www.holley.com/20-134.asp Havent installed it yet so the website is the best pic I can find... |
#6 | |
1972 C10 LWB Highlander Dark Olive/White - Work in progress 5.3/6L80e, Accuair e-level, Porterbuilt Stage 1 front and Stage 2 rear, Wilwood 14"F 13"R, Vintage Wheel Works V40 18x8/18x11, and more... Build Thread |
It looks like yours is a 5.3 truck LS correct?
Did you have to change the truck P S and alternator bracket? Did the bracket come with a tensioner/ideler? The water pump looks to be a truck, but the instructions say you need to use Camaro what am I seeing in your picture? Sorry for all the questions, but I do not want to duplicate any more parts that do not work !!
#8 | |
Boosted Member
Well I guess I will put in a order, thanks for the help!
Which power steering pump did you use, the Saganaw or the two part pump?
Boosted Member
Stock LS 2500HD pump.
Does your PS pump have a remote resevor?
Vintage Evil
I was thinking the truck and 10+ Camaro units had the same front spacing.... just the alt/ps bracket is different...
![]() Join Date: Apr 2005
You are correct.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#15 |
Don't forget the water outlet is in a different location
#16 |
Vintage Evil
#17 |
the 2010 Camaro pump should be an ideal fit if everything else is stock truck acc.
is your truck motor a vvt motor? if so you wil need the l99 Camaro pump not the ls3 pump. |
#18 |
The 2010+ Camaro pumps are the same LS3 or L99. The only difference is the timing cover and harness.
#19 |
Perfect!, I was hoping it was the saganaw, thanks
I did not know if the 2500 and the 1/2 ton were the same
#20 |
Old member
Here is my LS1 bracket on the 6.0.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#21 |
Boosted Member
The only difference is that most (all?) of the 2500 pump are hydroboost pumps. They are externally the same, except for a 2nd oil return to the reservoir.
#22 |
My 5.3 in my 78 has a second return line, I wondered what that one went to!
#23 |
Well from the pic, the Holley will not fit between the inner fenders on the 46 Chevy, thanks
#24 |
Those aren't Holley brackets, these are:
#25 |
The pictures I posted are the Holley AC bracket, I just stayed with the original alternator bracket.
