Headers or exhaust manifolds
Ok guys I have a bagged 72 C10 with cupped lower control arms and 2in drop spindles so my issue here would be I tried a set of long tube headers and they are almost hitting the ground so I was wondering if y'all think a set of factory rams horn manifolds would work better for my application?
![]() Join Date: Aug 2012
Re: Headers or exhaust manifolds
What do you have motor wise? A stock 283 would have different needs than a built motor.
Doug Old Build Thread - 383/T56 http://www.67-72chevytrucks.com/vboa...d.php?t=540838 Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua 5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital http://67-72chevytrucks.com/vboard/s...d.php?t=778784 |
Manifolds or a pair of shortie headers will work better.
Java Mechanic
If you want compact *and* power you'll need to spend a bit. If you just want good looks and the raspy sound headers generate you can get a set of block huggers for under $300 (less if you don't want ceramic finish.)
If you want quality, tuned headers that tuck up tight you'll probably need Thorleys or a custom bending job.
Keith 11 Lincoln MKT -- Momma's wagon ![]() 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
#6 | |
If you don't want shorties, 2nd gen Camaro long tubes fit well on a truck in most all instances.
Go with shorties... Great sound with the extra clearance...
