Old 05-15-2014, 09:03 AM   #1
wpotter
wpotter's Avatar
87 Chevy Truck - Interior Electrical Noise Question
What do I check? My truck has a whining or buzzing noise inside similar to a radio interference noise. It is a radio delete truck so I know its not that. Makes the noise with a/c on or off. Anyone know what I should check next. Thanks
Never a failure, Always a lesson!
1968 Chevy SWB Fleetside ECE 4/6 327/350
1987 Chevy V20 Scottsdale 4X4 350/400 4.10
1987 Chevy Custom Deluxe SWB 305/7004R4
1991 Suburban Silverado V1500 4X4 350/700R4
2015 Chevy Crew Cab SWB (Daily Driver) 5.3
wpotter is offline   Reply With Quote
Old 05-15-2014, 12:07 PM   #2
tex_waco_usmc
Project Heaven in my 67!!!
Re: 87 Chevy Truck - Interior Electrical Noise Question
Check your cig lighter. I was hearing a whining noise as well and looked inside the cig lighter and it was badly corroded/didnt work... Replaced with a 12V power supply that fit the hole perfectly and the noise is gone, and bonus now I can charge my cell in my truck...
tex_waco_usmc is offline   Reply With Quote
Old 05-15-2014, 01:31 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
does they key/headlight/belt buzzer work?I think 87 just unplug from the box
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 05-15-2014, 03:57 PM   #4
wpotter
wpotter's Avatar
Its more like engine noise going through something. When you rev up the engine the noise gets louder. Can only describe it as one like in a radio going through the speakers. I am going to trouble shoot some more this weekend, just not sure what.
Old 05-15-2014, 06:01 PM   #5
rudey737
I had a whining/grinding type noise that I couldn't place. It only happened while I was rolling, but not when I was sitting still and revved the engine.
I thought it was a bearing. I thought it might be a rotor. It couldn't be either one because I replaced the rotors, calipers, and discs when I lowered the truck and replaced all of the bearings.
Until I got on here and did a search. I found out that the speedometer cable can make the exact noise I was hearing if it needed to be lubricated. So, I lubricated it. And the damn noise is gone. Some will tell you the right way is to unhook the cable from the back of the speedo, pull it out through the firewall, unhook it from the transmission, pull the cable up most of the way out of the sheath and then put it back in while lubing it with white lithium grease.
That probably is the right way. I just unhooked the cable from the back of the speedo and then sprayed some motorcycle cable lube in the sheath, making sure it got onto the cable. That worked for me.
I needed to replace the parts I did anyway - I had no idea how old any of those parts were - but I might have waited until I could rebuild the entire front end. Now I have to go back in there and rebuild the ball joints, tie rod ends, pitman arm, idler arm, and control arm bushings.
Azulita - 84 Chevy Scottsdale Longbed 305/350
rudey737 is offline   Reply With Quote
Old 05-16-2014, 01:12 PM   #6
wpotter
wpotter's Avatar
I think it may be something to do with the distributor. Noise is coming through the firewall. Has new cap and rotor and wires so not sure exactly what it is yet.
Old 05-16-2014, 03:51 PM   #7
tucsonjwt
I have no idea what the problem is, but it reminds me of the static suppressors which were on my 1963 Corvette (and all 63-67 Corvettes). These were metal shields which were held against the block by the spark plugs and designed to suppress static radio interference. Just a thought - maybe you have a plug wire/spark plug issue? It is not likely, since you have a metal bodied truck, not a fiberglass bodied Vette.
tucsonjwt is offline   Reply With Quote
