![]() Join Date: Jul 2010
Need help mounting stock LS1 fuel pump in my tank
Hey guys, I have been looking for awhile now and I am not able to find a way to install the factory GM fuel pump into my tank. I am trying to avoid buying a new tank and really want to stay with the GM fuel pump. With so many of us doing the conversions you would think there would be an aftermarket mounting kit you could bolt in or weld. I have already modified the tank by welding in the filler neck and installing a baffle inside. Any help would be appreciated. Here's a picture to help clarify.
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
Re: Need help mounting stock LS1 fuel pump in my tank
Something like this? Not sure it will work on an aluminum tank, but you could probably copy it and make one yourself out of aluminum. http://www.vetteworksonline.net/cata...products_id=89
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#3 | |
Take a look at my build. I welded a ring to the top of the tank.
http://67-72chevytrucks.com/vboard/s...d.php?t=610252 |
Old member
I took the rig and matted it to another tank ring and cut it out then cut a hole in the tank to remount with sheet metal screws and a good gasket. Simple no welding. It has leaked a drop since back in the early 90's when I did the TPI swap.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#6 | |
That definitely sounds easier to do. Do you happen to have any pics? Thanks
Thanks for everyone's help. I used some hole saws today. This is what I've done so far. I still need to drill and tap my threads and weld the bottom plate in the tank.
Pic 2
If you decide to make your own plates I used 1/4" aluminum plate. Cut your opening on your tank 3 1/2" so your O-ring can sit on. The bottom plate that is going to be welded to the tank hole saw ID 4" X OD 6". The top ring ID 3.50" and OD is 6".
These look very nice. I did mine similar. I did drill and tap the bottom ring.
#11 | |
looks killer! that pump has a built in vent right? gotta have that vent, I learned the hard way, lol.
I'm not sure. I will take a look at it. Thanks for the heads up. I did find out GM discontinued the fuel lines on the actual pump. I ended up going to my local hose place and found some lines.
