Old member
While I'm on the 2014 Power Tour next month I'm going to see if I can get a deal on a cam and roller's for the 6.0 LQ4. There will be Eldelbrock, COMP Cams
Painless Performance Holley Hotchkis Performance all there as sponsors so I should hopefully get a good deal on it. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Cam & such
i have bought a lot of cams over the years and the two places i have been treated best was ultradyne and cam motion. I know the other brands you mentioned are sponsors of this site, and everyone's gotta get a buck somehow, including this site's owners. I will say I have never had a good cam related experience from the major cam brand you listed, and actively discourage people from buying them.
#3 | |
![]() Join Date: Apr 2005
Re: Cam & such
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#4 | |
Truck and auto performance nut
Re: Cam & such
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
Re: Cam & such
good luck and putting in a cam will really wake up that 6.0!
Just don't over cam and you will enjoy it so much more. I have personally used texas speed and tick performance myself with great results. cheers bpatrol |
Re: Cam & such
we will change it in the parking lot...You up for that?
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
Re: Cam & such
one was soft and the other didnt match the spec card. really no biggie, **** happens especially with a big company.
i'm just going elsewhere next time. every buck is a vote and i'd rather vote for the little guys. i wanna be able to pick up the phone and call him and that's worth and extra ~$75 i'd say. Last edited by littlevictories; 05-17-2014 at 10:39 AM. Reason: added for clarity |
Re: Cam & such
and i should retract that statement about never having a good experience with the major
i had quite a few good experiences up until i had some sour grapes. I heard they were farming custom cams out or something and that caused my grief. I dunno. I hate s-talkers so imma just shaddup. i still got their stickers all over my tool boxes. just my 2 cents really. if you wanna have your ear gnawed raw about cam stuff, give howard a call. that guy has forgotten more about cam design than most cam designers have ever learned. |
meowMEOWmeowMEOW
Re: Cam & such
The problem with some of the "big" companies, is a little bit of "slight of hand"
There are only a small few companies who actually MAKE cam-blanks. There are a FEW that buy their blanks and grind their own. The MAJORITY have the same large company grind their cams to spec. VERY FEW actually make their own blank, and grind it in-house to spec...its just too much setup cost. So, what ends up happening is 10 companies sell different "versions" of the same basic grind #'s. Comp can grind 1 cam, more or less the same way, for 10 companies who sell it as something different. I like Texas Speed and Pat G, both of which I believe are on Comp blanks. Tick's Polluter cam is also nice, but borderlines over-camming an otherwise stock motor. I'm using the TSP Tsunami, and I'm admittedly over-cammed for the setup. Once the my heads are on, that will change.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Re: Cam & such
I've put a few tick sns cams in fbodies with only a stall and I have to say none have been a disappointment. They all perform great and sound nasty.
Not much weight difference between one of our trucks and a full weight fbody.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's. 68 Charger R/T - #'s matching 440/auto car, 499/727/3.91. 68 GTX - 440/4-speed, Dana 60. 44,000 miles. 71 SWB C10 - LQ4+S476r 06 Duramax - LBZ - Exhaust, EFI Live, etc... |
motor exploder
Re: Cam & such
I went the conservative route and put a Comp LSr 265 in my 5.3 along with a Yank TT2600 stall & Blackbear tune. Runs very well for a 5200# ('05 GMC ccsb w/me in it) truck. Over 30k miles since the swap and no issues at all.
I also have a custom Bullet hyd roller cam in the 468 BBC I built for my '69 C10, spec'd by Chris Straub. For a stock engine, nothing wrong with an of the shelf cam from a company like Comp as long as you don't get crazy with it and match your parts accordingly.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
Re: Cam & such
Getting an off the shelf cam is foolish when there is minimal cost difference.
Call Martin @ Tick and get one spec'd for your application - gear/converter/weight and know it's done correctly and leaves nothing on the table.
#13 | |
meowMEOWmeowMEOW
Re: Cam & such
If you call Martin with an otherwise-stock setup, you'll still get a shelf-grind cam....it just won't have a "name". That being said, Tick does make good cams. On a stock setup, the 50-100$ for a "custom" grind isn't really netting you anything different. I'd put the difference toward a convertor and get a combo that makes the best use of its entire powerband.
Re: Cam & such
Tick and all the others pick the lobe combinations. That's what separates them from an OTS offering via Jegs/Summit.
Cost difference between one of Tick's grinds and a custom cam is $20. $20 well spent. |
#15 |
Certified BFH Operator
Re: Cam & such
since we are on custom cam chit chat, I'm curious now just how many companies are slinging the "Custom grind" lingo around.
Last year about this time, Ed Curtis ground me a cam. He was more than helpful and even gave me Brian Tooleys info to call them to get the rest of my valvetrain set up properly (Which I did). Unfortunately I have not gotten around to putting all the goodies in my '04 6.0L yet. Its probably a bit overkill but like Brew City, by the time everything is together, it should be right at home in my motor. But this was my first custom...err... Non-off-the-shelf cam and I have not gotten to see the results of changing to a ground cam as opposed to an off-the-shelfer. Just curious to know how much of the cookie cutter cam stuff is really out there now and if the extra $$$ will show through for the custom grind
- 1969 swb C/10 fleetside -LSx swap and Resto in progress LQ4/TH400/Ed Curtis cam/Pro Flo intake/Brian Tooley Goodies ..... a couple snails may be trying to crawl into my engine bay... ![]() -1997 Z/28 - LT1/T-56 - Bolt ons, 9 inch, built trans/clutch and on the bottle |
#16 | |
meowMEOWmeowMEOW
Re: Cam & such
If you count up the companies that straight-up grind their own cams, you can probably have a few fingers or toes left to count on. The VAST majority of even the bigger companies have their cams made, or sourced from CMC, Engine Power, and another company that I think is now a subdivision of Federal Mogul...the people that make a huge market share of parts-store replacement stuff. These same companies made the O.E. stuff for most companies.
#17 |
Re: Cam & such
Ah, nicely worded.. makes sense. Too bad the cam business isn't as we sometimes envision it (or maybe I'm crazy). A guy at a lathe loading a solid rod of billet and looking at the email you sent with a scribbled page of numbers to make the perfect cam for each individual lol
Sorry for the Hijack Andy, hope you score some good stuff on the Power Tour. Always wanted to cruise a leg of it but never seems to work out. Best of luck to you!!
#18 | |
meowMEOWmeowMEOW
Re: Cam & such
My very good friend designs engine parts for a number of O.E. companies. When he designs a new cam for an engine, he simply selects the model for a particular blank or lobe design. Then he does the math and engineering work to figure out the event timing. That file gets sent to a specialty machine shop that runs batches in the machine. You can still find dudes who "hand" grind cams for little engines, vintage motorcycles etc....but for the modern engines its just not they way things are done anymore.
#19 |
Old member
Thanks guy's for all the info on cams! I still want to check with the vendors during the tour!
Well as stated since I have 7 days with all these differant vendors hopefully someone will have a deal on their cams for the 6.0's while I'm on the tour. ![]() ![]()
#20 |
Re: Cam & such
i really like the image of a guy loading a machine and making em one at time.
some years back I was interested in cam design and priced out some machines there is always a market for weirdo cams, 401 nailheads, amc guys etc... a decent storm-vulcan grinder was running $10k, probably more now so i bought another comp cam and stfu |
#21 |
Boosted Member
Re: Cam & such
Martin was great to deal with. My Tick turbo cam is so much more responsive than the Speed Inc grind I had before.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#22 | |
Re: Cam & such
You couldn't pay me to use an OTS/generic Comp cam.
#23 |
Re: Cam & such
I've always heard awesome stuff about Tick, and clearly the one in your blazer is working out. I'll definitely keep em in mind next time around. I have had a couple friends that used FTI with great results and were easy to deal with over the phone and emails. I figured thats more than enough reasons to give them my business.
#24 |
Re: Cam & such
This guy is grinding old school valves, but the image in my head isn't too far off from what I would hope a cam maker should look like lol
#25 |
meowMEOWmeowMEOW
Re: Cam & such
For RC engines
