Np208 married to an sm465?
Found an sm465 thats attached to an np208. My 85 k10 has the 700r4/208 setup currently. The 465 in an 87 blazer with the hydraulic clutch. My question is if i were to get everything i need for the auto to manual swap can i use the 208 from my 700r4 and attach that to the 465 or do i need to get the t case along with the tranny? Thanks guys.
Re: Np208 married to an sm465?
Someone else may need to chime in, but I believe that they used different input shaft spline counts in the autos and the manuals.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
ive been looking for a set up for a project what ive read is the 350/700 is 27 and the 465/400 is 32 spline.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
Thanks a lot guys, i will have to just buy the tcase with the tranny. now my next question would be can i use my current drive shafts with this transmission? i know the 465/205 is shorter so i would need longer drive shafts but is that the case with the 208 also?
You may be able to use your driveshaft's. I am pretty sure the adapter for the 465 is longer than the 700's. Measure from the block to the back of your transfer case before you go to pull everything.
Well i went and pulled everything today. Got the driveshafts just to be safe. And its a hydraulic setup, which will be very nice.
