Old 05-17-2014, 07:57 PM   #1
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Evaluating my 15" front tire choices.
So, I'm trying to get my front tires setup for this year. I tend to buy 2 tires at a time due to the staggered wheels.
My truck started off with 235/60/15. Not the most common size, but seemed to fit the (iirc) 15x8 M/t's well, and felt/handled decent up front. (my m/t 325 dot's are in the rear)
I lost a tire a little early, and had to hurry to get a new set of fronts before a trip. Due to time and local availability, I ended up just throwing my "spare" rear combo on the front, a 235/70/15 on the same rims. It raised the front end more than I'd like, and they +camber too much, making it touchy. I'm keeping them for a rear spare, but don't like them on the front.
So now I'm faced with finally finding a "correct" front tire that feels and fits good....but that I can FIND. I've found a few 235/60/15's and could go back to that size OR I can switch to the easier-to-find 215/65/15.
The 215/65 will give me the sidewall height I liked on the 235/60, within 2mm. BUT I lose about 20mm of section width. Ok as a front runner, but do you think its too narrow for a steering/stopping tire?
What yall think?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-17-2014, 08:59 PM   #2
BossHogg69
motor exploder
BossHogg69's Avatar
Re: Evaluating my 15" front tire choices.
I was always a fan of the 235/60/15 - I ran them paired with a 295/50/15 in the rear on a 5/7 dropped '92 ecsb c1500 I had back in the day. A 215 seems awful skinny for truck tire up front, but I have nothing to back that up vs a 235/60.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 05-17-2014, 09:29 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I like 215s on the front. As a matter of fact, I'm running 215s on the front of my stepside right now. They perform fine and they're easy on steering components. I think if you'll ask Scoti and Lolife they will both concur. Between us, we've run the 215 combo on a lot of trucks.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 05-19-2014, 08:44 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I've got a vote going either way now
Allow me to expound upon my thoughts;
235:
Upside
I've driven on a 235 already and know how it should feel, which is nice going in. The width of the tire is nice for stability and contact patch for braking (my hydroboosted d52s lockup nicely, but I have uncooled drums on 12" wide steel wheels out back, so the front is REALLY doing most the work).
Downside
Seems to really start to become limited on tire choice and availability. I don't like having to switch brands everytime, or end up with mistmatched tires side-to-side because I can't find a matched tire in a pinch. Price for some of these tires.
215:
Upside
Skinny tire works better as a front-runner on my pro-street style truck, makes the stagger look mean. The side profile is the same, so they should feel similar going down the road, with a slightly higher chance of understeer from less tire. About double the tire choice, and prices down to $70some dollars for tires. Even Bfg's as low as 80 with the choice of some Grand Touring and HP all seasons, which is nice for a summer truck. I don't need real front-runners, but I don't want to put a hard mega-mile tire on this thing either, ya know?
Downside
I'm a little concerned about the contact patch for braking considering the concerns mentioned above. I also have pretty light steering with the hydroboost on the 71 rack, and the 2005 pump. I don't want the narrow tire to become twitchy, but my alignment guy has me setup to a pretty good road-center so that might not be an issue.
Anyone else want to weigh in? We drive this thing on the road a ton, occasional strip use.
Old 06-03-2014, 06:39 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Cmon folks I need a little more insight before buying some new meats.
Surely me, Boss and Tx Firefighter aren't the only 3 with a 15" front wheel.
Old 06-03-2014, 07:14 PM   #6
Tx Firefighter
I don't know why Scoti and Lolife haven't spoken up. Those guys have definitely run 15s under low trucks and Scoti is the guy who steered me out of my 60 series tire rut and into taller, skinnier tires that I run now.
Old 06-04-2014, 03:29 PM   #7
gottattooz
gottattooz's Avatar
If you go to www.tirerack.com, you can plug in any tire size and it'll give you the specs of whatever tire you're looking at. I'm running 15X8 1/2 fronts and 15X10 rears on my 68. I've for 245/60R15's up front. I had 295/50R15's out back, but I just swapped for 275/60R15's to get better mileage, as the Speedometer is off by about 10%. For the 8 inch front wheel, a 235/60 or 245/60 has a decent sidewall that's not a rubber band that you'll feel every bump in the road.
-Josh
1967 Buick Special wagon
1968 Jeep Wagoneer
1958 Chevy Panel Truck
2017 Suzuki M109R
gottattooz is offline   Reply With Quote
Old 06-04-2014, 05:03 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
-Josh
245/60 is a little too wide for the fitment as the 235/60 is as wide as I can comfortably go without scrubbing fender.
Its gotta be the 235/60 or the 215/65, just need to figure out which.
Old 06-04-2014, 05:18 PM   #9
Custom 68
Custom 68's Avatar
I guess it depends on your "look" I like wide all the way around but big and little or staggered look is a cool look.
Currently I am kindof staggered I am running 18s but have 255/55-18 front and 285/5018 rear. Prior to that I was 275/60 15 all the way around. That was a big tire...
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is online now   Reply With Quote
Old 06-04-2014, 05:20 PM   #10
Special-Ed
Special-Ed's Avatar
235 is what i would go with... cuz wider is better.
sidewall i like more sidewall..feels softer, so i would not go smaller than a 60 series
with tire choices, in my opinion, its really all about what you are trying to acheive. and how much road you need to hold with the tire.
for me its all about comfort...
now for performance wider and shorter is where you want tot be.
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 06-04-2014, 05:30 PM   #11
Custom 68
Custom 68's Avatar
I will include this old link it may not be applicable but it is one I subscribed to years ago when I was running 15s it was mainly for the tire brand not the size specifically. It seemed like I was limited in brands on the performance side at the time with the 15 inch but now I am not sure.
http://www.pro-touring.com/threads/3...which-to-chose
Dave
Old 06-04-2014, 05:39 PM   #12
lolife99
67-72 parts collector,…
lolife99's Avatar
Super low static dropped trucks with the inner fenders installed can't run a very tall front tire.
On the front is a 215/70-15 on a 15x7 wheel.
They look kinda short on a stock height truck,... but pretty good on a 5.5" front drop.
The rear is a 275/60-15 on a 15x8 wheel.
Keith
Convert to disc brakes.
Old 06-04-2014, 07:10 PM   #13
SCOTI
SCOTI's Avatar
It's really personal preference. I've ran BFG's in both 235/60 & 215-70 sizes on 6x-90 model trucks. Both work fine IMO but I don't really disect the specifics your concerned with.
For me, I like the sidewalls to be symmetrical. So if I run a 325 on a 10" rear wheel (325/25.4)/ 10"= 1.27. 1.27" x 8 (your front wheel width) x 25.4 = 258mm. I then find the closest tire size to that w/the height I desire so if this was mine I'd do 245/60's or run a 7" front wheel & a diff size.
If 245's will rub, stick w/the 235/60 combo.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
