Old 05-18-2014, 04:09 PM   #1
68Mike
68Mike's Avatar
Question Possible lead on 6.2 so now I have LOTS of questions
So I may have a good lead on 2013 yukon xl and I believe it has a 6.2 in it. Looking to put in a '69 c10 which currently has a sbc 350.
My question is what all would I need to pull besides eng, trans, engine wire harness? I'm sure there are some modules that I'll need but have NO clue as to which ones and where there at. Any help is greatly appreciated.
Mike
Currents:
'74 Cheyenne Super C30 Camper Special 3+3
aka "Sucia30"
Past:
'79 C10 BIG 10 (Sold)
69 CST LWB - Always a "Work in progress" true work truck (stolen)
05 GSXR 750 it has a pretty paint job _wrecked
72 SWB full frame restoration -sold!
71 CST K5 Blazer 4x4 (soon to be 2wd)-project - sold!
C10 Club 2012 Brothers Show Video
http://youtu.be/pUeV2vP7Wpo
68Mike is offline   Reply With Quote
Old 05-18-2014, 04:30 PM   #2
trkfrk
trkfrk's Avatar
Re: Possible lead on 6.2 so now I have LOTS of questions
I would try to get the fuel pump out of the tank or maybe even the complete tank with harness's. O2 sensors and exhaust manifolds. Good luck on picking up engine. That will be a sweet drive train
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 05-18-2014, 05:10 PM   #3
solidaxel
solidaxel's Avatar
Does this have VVT or DOD and what is involved with programing these options out???
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-18-2014, 06:48 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Stock manifolds don't fit most frames unmodified, so unless you want to flip them for turbo in the future, I wouldn't bother.
Aside from the engine, trans; take the ECM, BCM if applicable (you may not need it depending on the features your' running, but taking it now saves having to find one later if you do require it). Take the DBW pedal, all its wiring, the TAC (if applicable). You can take the fusebox if you want to reuse it, some do, others choose not to because an aftermarket one is a tad cleaner.
Take the driveshaft yolk, or the whole shaft if you want. Depending on what tranny you used to have, you may need the other yolk (i.e. 4l80e can't use a 700r4 yolk)
As for the AFM/DOD; it requires tuning AND hard-parts changes. Non-AFM/DOD cars use different cam layout, pcv gets plugged etc. You can see the parts kits
http://www.texas-speed.com/p-717-dod...elete-kit.aspx
There is tuning associated with this also.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-19-2014, 09:58 AM   #5
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
Texas speeds has the complete kits or these are just GM parts so if you have a good relationship with your stealer then they can usually get you the parts cheaper...
I am currently working on a '10 6.2 from a Denali... Feel free to PM me if you have questions as I have done pretty much all the conversions we are discussing here...
chevyguy_72 is offline   Reply With Quote
Old 05-20-2014, 04:16 PM   #6
Hart_Rod
Hart_Rod's Avatar
You can "tune" out the Active Fuel Managment (DOD, displacement on demand). If you plan on going high HP with a high lift CAM, then the hard parts should be removed. If you are planning on just making a good driver, I would leave it in and then make adjustments to the tune that will only let it drop to the 4 cylinder mode when in 5th or 6th gear. Just my .02.
Hart_Rod is offline   Reply With Quote
Old 05-21-2014, 05:02 PM   #7
First c10
First c10's Avatar
That's what I want to have my ECM tuned like. Leave it but only at highway speeds.
It is amazing what things you can do with these motors.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 05-22-2014, 10:08 AM   #8
solidaxel
solidaxel's Avatar
Glad to hear you folks understand how to do this!
LS 3 4L70E
