Rear Sway Bar
I have been tossing around the udea fo a rear sway bar for some time. I [ut the front one on last summer and was pleased with the results. Last week I went to a salvage yard and found a rear sway bar on a 95 gmc yucon. Today my brother and I put it on.
Brian ![]() |
Re: Rear Sway Bar
Welcome to the site from across the river. I'm not far at all from you good job on finding a newer part that fits the older stuff. Jim
Re: Rear Sway Bar
wow that's awesome! did you run into any issues installing it?
![]() USMC SEMPER FI 68 Chevy Longhorn 350/400 factory posi |
![]() Join Date: Apr 2012
Re: Rear Sway Bar
I'd like to know what you think about it's performance after you test it out. I've read that rear sway bars are frowned upon in these trucks since they are so light in the rear.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
Re: Rear Sway Bar
I see that sway bar wouldn't work on a coil spring rear
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
Re: Rear Sway Bar
My 67 stepside has the ECE 1 1/4 in sway bar in front and the CPP 3/4 in bar in the rear (and yes, it IS for a coil spring rear). When I drop back to 15 in rims (from 17's with street tires) for an autocross the sports car guys laugh because it's a truck. When my time is posted they are all thankful I run in a weird class because that truck is quicker than a Lotus Exige and a Porsche Boxster S. The only thing in the local club I can't beat is an Ariel Atom.
#7 | |
Re: Rear Sway Bar
Re: Rear Sway Bar
Nice job. See my Camaro sway bar on an AD truck.
![]() Join Date: Jul 2007
Re: Rear Sway Bar
My truck still rides like a Cadillac but stays firm in the turns.
Re: Rear Sway Bar
Normal driving is the same. The truck will ride as soft or harsh as the shocks and springs you use. Since my front and rear springs have the same compliance as the stock springs I see no difference. It took me a few tries to get used to how it corners. Flat, and fast is the only way to describe it. The first time I did a 90 it was very hard to resist standing on the brakes but the truck went around almost as fast as my Z51 Corvette.
#11 | |
Re: Rear Sway Bar
Re: Rear Sway Bar
twitch, the biggest problem I had was moving the moving the short piece from being mounted on the outside of the bar to the inside of the bar.
66 skylark---- from what Ive seen, the ones for a coil rear end are dufferent.
Brian ![]() |
Re: Rear Sway Bar
I bought the LMC aftermarket one and I wouldn't recommend it. It's a bit better now with the weight of the bed and so on, but as you can see I had to put it in a weird place because the end-links aren't long enough to reach the frame.
So, I conclude that the bar certainly isn't made specifically for our trucks. Once I get closer to final stance I will likely change the end-links.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
Re: Rear Sway Bar
I used a rear anti-swaybar from CPP it fits like a glove some drilling and some patience to get the bar level took about 2 hrs install time.Now for the road test
Holy awesome i have no more shimmy shutter bug over rough roads and it hugs amazingly in tight corners sorry I don't know how to put images up |
#15 | |
Re: Rear Sway Bar
#16 |
Re: Rear Sway Bar
I have one that is mounted in front of the axle. It clamps on the frame and control arms. I believe it was from performance suspension in Phoenix. It makes a big difference on my truck. My truck sits a bit lower than most stock trucks but it was not lowered. It is a coil spring truck and tightened the rear up nicely. It does not seem to make the truck loose but stays flatter through the turns. I still have the stock one up front. I run Monroe Reflex shocks.
#17 | |
Re: Rear Sway Bar
#18 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: Rear Sway Bar
Is anyone running either of these rear sway bars. There is a good price difference between them.
http://www.suspensionconnection.com/...-sway-bar.html http://www.suspensionconnection.com/7401c.html
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#19 | |
Re: Rear Sway Bar
![]() Here's a link: http://www.classicperform.com/Store/...uck/CP7401.htm $179.00 puts it right between the two you found. |
#20 |
Re: Rear Sway Bar
I added the rear sway bar from CPP along with front sway bar from another truck to my 72 suburban and it is a huge improvement and handles a lot better now.
