? for you guys that lay frame
For the guys that are bagged and laying frame, how did you do the front crossmember? This is for the guys that didn't go the dropmember route. I've read many build threads and there's a few ways to skin this cat. From Z'ing the frame to sectioning the the crossmember. How high did you have to raise the control arms to be above the bottom of the frame rail? I'm hoping to hear from personal experience what route people have gone and the pros and cons or if they would do it differently now.
and a few others
Re: ? for you guys that lay frame
Here's some reading to get you started:
http://67-72chevytrucks.com/vboard/s...hlight=xmember you can do a search for pancake xmember or crossmember to find others.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
#3 | |
I have a one inch sectioned crossmember for sale in the classified section if you are interested btw.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
Mine is still a work in progress.
I was told, "don't be afraid to cut". |
I really like this guy's build http://67-72chevytrucks.com/vboard/s...d.php?t=269019
my friend channeled his cab 3 inches you can see it in this pic. when its down it lays rockers.
Between saying and doing many a pair of shoes are worn out ![]() |
Well, I've jumped into cutting up a crossmember. Took out 2" and hopefully will have it all welded up this week. Thanks for the replies guys. Lots of different approaches out there, that's for sure.
For the people that have done the pancake, has anybody slid it forward when putting it back under the truck to help recenter the wheel? Is there a problem with moving the steering box forward too? Seems like it shouldn't be to big of a deal since you've got to reposition it up anyways. |
What are you going to do about your steering?
Well, in my mind I would like to go with a r&p setup, but my wallet is telling me that I'm going to stick with the p/s box that I have laying around. I have the section of the frame that the p/s box mounts to. I'm thinking that I could graft that piece into my frame so that it lands the box the 2" higher and 1" forward to keep the original geometry. Of course there'd need clearance for the linkage and have to use some heim joints for the column shaft too. This is just a thought that I have in my head right now. I'm thinking that once I have the crossmember up into place I'll be able to see if it's even possible. Sound like it's doable to you? If not, I'm open to suggestions.
2" Pancake
Stock Frame Bridge ![]() ![]() Moved the steering up an inch. 75 C10 power box. S10 pitman. Frame notch for the ptiman. ![]() ![]() A arm notch and custom linkage ![]() |
^^That is how mine is done on my 66. I got it that way. I'd probably go with a Z had it not already been done
#12 | |
Why would you go with the z? Is there something about the way yours is done that you don't like? |
#13 | |
Thanks. Pretty pleased with how it has turned out. You can't move the box up a full two inches because the harmonic balancer will hit the center link. The S10 pitman is much flatter than the C10 counter part. The profile is a much closer match to the stock idler arm. |
#14 | ||
![]() and doing that plus moving everything up and notching is a lot of work for only 2 inches. Then move the body down to get rid of the frame.....It was already done when I got the truck (I still need to do some finishing work on it) so I'm not complaining. ![]() Quote:
![]() ![]() (I included a bunch of pics of my work and trucks because everyone loves pics ![]()
#15 |
WCHLVR - Good looking truck btw!
#16 |
#17 |
Yeah I am going to keep it 8 lug. Never going to tow anything but I am playing with the idea of a turbo LS (already have the LS) so I figure the 8 lug rearend couldn't hurt.
Back to the original poster. DV8 (a board member here) did his own version of a raised crossmember that he has shared the measurements on before. Shoot him a message if you are interesting, he is usually very helpful.
#18 |
On my '63 I sectioned my '73 crossmember 2" and re-bolted it 1" forward.
There was not room to move the steering box up 2" and forward 1"I - it would be in the middle of the core support bracket - So I figured out how to install a R&P unit and matched where the center link would have been at 2" up and 1" forward. |
