Lowering springs too weak for a bbc???
I'm going to use 3" drop spindles but was thinking I may want to lower it a couple of more inches. What I'm worried about is the spring rate, will typical lowering springs carry a bbc??
Re: Lowering springs too weak for a bbc???
Drop springs typically have a higher spring rate and I would ASSume they would feel better in with a big block over a small block.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
![]() Join Date: Aug 2012
Early Classic sells drop front coil springs in 1" & 2" in big block versions along with stock height springs. Small block versions also have a 1.5" drop version in addition to the other drops.
I'd give them a call and talk to them.
Doug Old Build Thread - 383/T56 http://www.67-72chevytrucks.com/vboa...d.php?t=540838 Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua 5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital http://67-72chevytrucks.com/vboard/s...d.php?t=778784 |
Thanks. I'll give them a call.
