05-22-2014, 03:45 PM | #1 |
Do I have the wrong gas cap?
Just went to take my gas cap off after replacing it recently. First time I have taken it off and there was a good amount of vacuum. I am thinking that maybe I got a non-vented cap by accident? Are we supposed to run vented caps on our trucks? BTW I have the in-cab tank with a V6 and Holley.
05-22-2014, 03:56 PM | #2 |
Re: Do I have the wrong gas cap?
Should be vented...sounds like it's not.
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
05-22-2014, 03:57 PM | #3 |
I'm guessing if there is vacuum on the tank that means not vented cap? Would vented mean there is a one way valve to let air into the tank but not let gas/fumes into the atmosphere?
05-22-2014, 04:19 PM | #4 |
Gas fumes will go into the atmosphere. You will be able to smell gas around the gas cap on a vented gas cap.
05-22-2014, 09:46 PM | #5 |
Last 2 I bought at parts store and truck supplier ended up not vented . I took small plastic cap on bottom side of cap and took out spring and rubber check valve. Put small cap back on works now. Cheap fix.
05-23-2014, 10:26 AM | #6 |
If a vented cap is gonna make me smell gas around the cap then I'll leave the non-vented and just crack it from time to time. Doesn't seem to be much of an issue and I am sure I'll eventually do an engine swap with return line.
05-23-2014, 01:20 PM | #7 |
Without a vented cap you may eventually collapse a line or the tank. At a minimum it can cause fuel supply issues. The vent is mainly to allow air in to replace the fuel going out.
05-24-2014, 12:44 AM | #8 |
on a hot day it will also cause vapor lock, fuel will boil a a lower temp n a vacuum.
Current Project : 1962 Chevy SWB Fleetside Others, 1958 Edsel Villager Station Wagon 1926 Ford Model T Roadster Hotrod www.suedescarclub.com |
05-24-2014, 02:16 AM | #9 |
Hold it right there...
1965 GMC 4WD 3/4 Ton Fleet V6 SM420 D44/60 I request lots of pics of this truck. |
