05-24-2014, 09:49 PM | #1 |
WTB 60-61 Chevy, front 6 lug hub.
WTB 60-61 front 6 lug hub.
I'm looking for a front hub for a 1960 Chevy Apache. |
05-25-2014, 09:30 AM | #2 |
Re: WTB 60-61 Chevy, front 6 lug hub.
I've got both front hubs off a 63. don't know if they are the same. they are complete spindle to drum.
05-25-2014, 09:36 AM | #3 |
I have a few also.
05-25-2014, 03:27 PM | #4 |
Don't know if the 63 hub will fit.
The hub: center need to be 3" , 6x5.5 I only need one. How much shipped to 30349? Send me a pm. |
05-25-2014, 04:06 PM | #5 |
hub diameter measures 3 9/16. let me know if you're still interested.
05-25-2014, 04:21 PM | #6 |
If you have a torsionbar frontend only hubs drums & bearings from a 61 &62 torsion bar frontend will fit. 63 parts wont work.
05-25-2014, 04:56 PM | #7 |
Yeah, my hub is attached to the drum.
Thanks |
05-26-2014, 04:12 PM | #8 |
I have some off a 62. What all are you wanting?
05-27-2014, 12:22 AM | #9 |
Bregion,
I need the hub with the drum attached. |
05-27-2014, 10:19 AM | #10 |
This work for ya?
05-27-2014, 05:32 PM | #11 |
What the other side look like?
How much shipped to 30349 |
05-27-2014, 08:19 PM | #12 |
Other side. Ill check on shipping. I bet its gonna cost alot with neing so heavy.
05-27-2014, 09:49 PM | #13 |
Hey Bregion,
To reduce the weight remove the pin,nut,up to and including the bearing and hub. don't need the rest, brake shoes etc... |
05-27-2014, 09:56 PM | #14 |
You can grind off the rivets that hold the brake drum to the center hub. that will allow you to separate the drum from the hub. the center hub will then ship in a us post office flat rate box.
05-27-2014, 10:18 PM | #15 |
yes, but I need both the center hub and the drum together.
05-28-2014, 08:58 AM | #16 |
If you need the drum also make sure you have enough meat in the drum to have turned. Nothing worse than buying a drum that is out of spec and you cannot have it turned. Then you get to buy a second drum. If your hub is good you can buy a new drum, grind your rivets out , install the new drum and good to go.
05-28-2014, 11:21 AM | #17 |
Paul,
Will I have to rivet the new drum to the hub? |
05-28-2014, 11:45 AM | #18 |
It is a good idea to re attach to your hub somehow whether by rivets or other means . Your wheel studs also work as attaching devices but rivets or bolts never hurt. Ask a good brake shop. Do not read it on the internet.
05-28-2014, 01:20 PM | #19 |
Ive ground them off and never bothered to reattach them and never had any problems. The wheel and 6lug nuts clamp it tightly. on many vehicles the brake drums are not attached to the drums. having them where they can be removed without disturbing the wheel bearings is handy.
