Driver door stuck shut.
I searched and couldn't find a specific answer to this question.
1964 GMC. My drivers door is stuck shut. Not totally shut but where it loosely rattles. The truck has been stood since 1993 so PB blaster has been used ![]() The mechanism pulls the 2 hooks away from the barrel that latches to the latch on the B pillar but that barrel doesn't seem to want to spin to let the door open. I may just be seized but I wanted to ask if anything obvious happens to stop that barrel from spinning? Thanks for any help and sorry for these annoying little questions. |
Chevy addict
Re: Driver door stuck shut.
Did you try prying it open?
Never Ending Projects
I ran into this once on my '65 truck. I had to use a pry bar to GENTLY pry up the door from the rocker while I had my wife pushing the button and pulling on the door. It finally popped open. I then readjusted the door striker so it wouldn't stick anymore. Worked perfect. Remember, up with the door, not trying to pry it open.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
![]() Join Date: Oct 2010
Is there anything you can do from the inside? Possibly take off the door panel and work on the latch from the inside of the door.
TAZ BUILDS 1966 GMC Suburban 1963 GMC Suburban Patina frame-on FOR Sale 1966 C10 Short Bed (2010-11) Monthly Updates 2015 C10 Pics with my '72 Montego GT 429/521 build 1963 Pro Street C10 back halved. Frame off I did back in 1990 Pics / Video |
Chevy addict
I just bought a 66 that the passenger door wouldn't open, even shouldering the door from the inside. Pushed the button on the outside and gently nudged it with a screw driver and it popped right open. After that it opened and closed fine but it needs a little oil. I have run into this situation several times with trucks that sit outside a long time.
Yeah the door panel is off.
OK. I'll try some levering today ![]() |
Did you get the door open?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Yeah just got it open yesterday.
Prybar and a couple of friends did the trick! I tool the lock mechanism out and the "star wheel" that latches onto the latch is completely seized. It started turning after about 24 hrs of spraying with PB blaster.
1964 GMC 1502, 3/4 ton wideside. |
Cool, glad its resolved!!
