Old 05-29-2014, 10:07 PM   #1
edgooch
8.1L swap questions
I am preparing to swap an 8.1L engine and 4L85e transmission into a 1972 3/4T 4WD Custom Camper truck (picture below). I have seen some info on this forum that helps a lot, but still have several questions.
1 what are the pros and cons of using the electronic throttle vs an older mechanical throttle body. I have all the parts needed to do either.
2. What motor mounts are best to use?
3. Who should I use to reprogram the ECM? I see members of this forum talk about Jim's Performance and Howell. I can't figure out which is best. Any opinions and recommendations would be welcome.
4. Did you have to change the front cross member to clear the 8.1 oil pan? Where did you get the cross member?
5. What about cooling? I have the radiator out of the donor vehicle ( 2003 suburban). Do I need it. The 72 has a pretty healthy radiator already.
6. The truck has a factory in-dash tach that works great. Can I make it work with the new engine?
7. What exhaust manifolds work best?
I am sure there will be many more questions as I work through this build. Any help and ideas would be appreciated.
72 Custom Camper 4x4
04 2500 HD - 8.1/Allison
edgooch is offline   Reply With Quote
Old 05-30-2014, 07:08 AM   #2
SS Tim
SS Tim's Avatar
Re: 8.1L swap questions
Best place to start is with the search button, there are a number of threads and a few builds as I recall.
Here is a thread of DirtyLarry's I'd bookmarked with a lot of great 8.1 info.
http://67-72chevytrucks.com/vboard/s...d.php?t=298696
If you would, how about posting up your SPID?
* VIN/Model Decoders
* Power Team Charts (engine/transmission/gear ratio)
* Post Your Pickup SPID Blazer SPID Suburban/Panel SPID
* RTFM
... Read The Factory Manuals... download 'em here
SS Tim is offline   Reply With Quote
Old 05-30-2014, 08:14 AM   #3
casper71
I used howell engineering. I have the fly by wire set up that works great. you can use 73-87engine mounts to install engine. with that engine and trans you will need new drive shafts, transfer case adapter, remote oil cooler, and standalone harness. Stock manifolds will require trimming the frame to fit, shorty headers will work best. you may also need to move engine forward as transmission is longer than original. This swap is a lot of work but is nice when complete.
casper71 is offline   Reply With Quote
Old 05-30-2014, 10:36 AM   #4
edgooch
Thanks! This helps a lot. Any idea where to look for the transfer case adapter?
Old 05-30-2014, 10:40 AM   #5
edgooch
"If you would, how about posting up your SPID?"
What's a SPID?
You're right, Larry's info will be invaluable. Thanks.
Old 05-30-2014, 11:12 AM   #6
ekgguy
ekgguy's Avatar
I used 150tunes.com for my pcm flashing and wiring harness changes. I sent them the entire harness and the pcm, they took off what I didn't need for my application and built an OBDII port into the harness.
Matt
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655
"Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!"
ekgguy is offline   Reply With Quote
Old 05-30-2014, 11:23 AM   #7
casper71
I used advanced adapters, you will need a two wheel drive output shaft on trans and some machining on transfer case. Sound scary but was real easy.
Old 05-30-2014, 11:26 AM   #8
casper71
I'm new to this, but what is a spid?
Old 05-31-2014, 12:25 PM   #9
edgooch
Based on some new info that I recently got from the Pirate 4x4 forum (great forum, BTW), I am thinking of using an NP241 passenger side drop transfer case from Midwest Transmission Center. It has the 32 spline input that I need and should bolt right up to the 4L85e tranny. Anyway, that's the plan now.
Thanks.
Old 05-30-2014, 11:18 AM   #10
67 cst swb
67 cst swb's Avatar
My boss used Jims Performance on a 2wd 8.1L/Allison set-up a few years ago. He was very happy with his products and his helpful service after the sale on unrelated issues.
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 05-31-2014, 12:28 PM   #11
edgooch
My son is looking for that same 67 cst short wide box that is your next project. Have you found one yet?
I keep hearing that Jim's is excellent at customer service during the installation phase. That's a big plus. Thanks!
Old 05-30-2014, 10:37 PM   #12
OldCreek
OldCreek's Avatar
I used an aftermarket engine cross member and the stock pan. The stock front 72 crossmember doesn't have to be changed. I think stock '72 bbc mounts and cross members should work. Use 72 stock bbc stock manifolds. Like Dirty said, it should be a simple bolt in mount up.
I used the stock 8.1 harness and computer. I flashed it with hptuners. Seemed to work fine but I sold it before i drove it. It did drive up the trailer and had no c.e.l. come on for the many months I had it running.
You should be able to use the stock radiator. I used an electric fan. And, I think you should be able to use the stock tach if you run a jumper/resistor to a switched 12v source...
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 05-31-2014, 12:06 PM   #13
edgooch
I hope to use the 72 raditor and an electric fan as well. Glad to hear of your success. The motor mounts and exhaust manifolds shouldn't be too hard to find. All good info - Thanks!
I am a little confused. You used an after market front crossmember but are saying that the stock one will fit under the 8.1 oil pan, right?
Old 05-31-2014, 12:49 PM   #14
OldCreek
OldCreek's Avatar
Lets be clear, there is the front crossmember and the engine crossmember.
The front crossmember stays put. The stock bbc engine crossmember can probably stay put… I used an aftermarket because I didn't have one. I think Dirty Larry used an aftermarket out of preference…I think it was an ORD high clearance one.
Old 05-31-2014, 12:57 PM   #15
edgooch
Sounds like I need to spend a little more time underneath the truck! I'll get it figured out.
Thanks. This helps.
cross member, ecm, electronic throttle, engine swap 8.1, motor mounts
