Old 08-01-2003, 09:41 PM   #1
OLDCHEV4X4
OLDCHEV4X4's Avatar
Intake manifold Question
Has anyone ever removed the oil splash shield under the intake manifold? I think it is held in with rivets that are pressed in...If i get a screwdriver under the shield i think i could pry them out...
Then drill and tap them for screws and install with lock washers and red locktite...
Anybody ever done this???????
I glass beaded my 1970 LT1 aluminum intake and i want to get all the glass out...
Any input would ease my mind befor i mangle my rare intake..
Randy
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 08-01-2003, 09:50 PM   #2
Jwill41
Jwill41's Avatar
I saw something about actually prying out the rivets and re-using them. I think they twist in and out.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 08-01-2003, 09:52 PM   #3
ddsmith
Glowing since 1978
ddsmith's Avatar
The things that look like rivets are actually threaded so to speak into holes. The best way to remove them is to grab them with vise grips and turn them to the left. At least I'm pretty sure the right way to turn them. You could also cut a small slot in them to make a flat bladed screwdriver work for removal. Believe me you'll be glad you discovered this before going through the drilling headache.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 08-03-2003, 10:46 PM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
Ok, the rivets dont twist out. They pull strait out. Actually i pryed them out with a screwdriver. I couldent get on them with the vice grips.. Their are krimps on the side of the rivets so that they get fat in the middle. So i peened the holes a little and put red locktite in the hole and hammered the rivets back in. They held tight..
So the intake is installed and the motor goes in this week.
Randy
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
