Brake help...
I put in a new master cylinder today (already bench bled) and began to bleed my rear brakes. At first some break fluid began coming through the bleeder line (very little actually) and then nothing. So i try the other rear break and again very little comes out then nothing.
I move to the front brakes and they move fine no problems. The fluid isnt moving at all in the rear reservoir. Whats going on here? Its a 69 1 ton with a booster and drum brakes ![]() |
![]() Join Date: Sep 2010
Location: Formerly MD and San Diego, now loving life in Arizona
Re: Brake help...
I had the exact thing happen on my '69. Here is what I found:
1. My bench bleed was not successful due to the lines I used initially had plastic nuts that would not seal around the threads of the master cylinder and allowed air into the fluid path. Purchased a quality set of bleed lines from NAPA, bench bleed problem solved. 2. I had a small clump of rust on the fluid line that ran between the frame and one of the rear crossmembers on the passenger side. My frame was rust and corrosion free, however there was a little clump of dirt that built up over the years where the line ran through the crossmember/frame location and completely rusted the line shut. In my circumstance, there was no fluid leak showing. It was only when I was looking for a kink or damage on the line did I find the clumped dirt/rust spot. Just as soon as I cleaned the hard dirt clump out and moved the line a bit, the line broke at that small spot and I found the rust had penetrated into the inner part of the line and shut off the fluid flow completely. I replaced the line and the bleeding process was easy after the repair. I would never have suspected a rusty brake line to cause my problems as I had a clean, rust free frame, but after a detailed inspection, I had found the problem described above. Be suspicious of the bench bleed process that was used. ALL air needs to be removed. With 2 persons, the bench bleed can actually be done while the master cylinder is installed in the truck before the brake lines are attached. Let us know what you find out.
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
Re: Brake help...
Thank you for the detailed response. I used the cheap plastic nuts also and the rear reservoir nut didnt seem to make a tight fit.
Before posting i made a quick glance of the rear lines and didnt see any damage. I'll do a more thorough examination tomorrow. Shes been sitting for awhile so it wouldnt surprise me if it had a rusty line. My initial thought was a clogged line but where was the mystery. Hoping i dont have to replace the entire rear lines. . |
Re: Brake help...
checked the lines and while there is rust along 95% on the surface how can i tell if the rust has penetrated? hmmmm
I guess the best way to know is just replace all the lines. |
Re: Brake help...
The porportioning valve has a stop slide in it. The rear brakes could be cut off. Check the FAQ section for brake work. A lot of guys use a clamp the force the valve back to center. The BRAKE light on the dash should be on if this is the case, assuming the light works.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
Re: Brake help...
Try disconnecting the rear brake line at the tee. With your reservoir cap off, see if it flows out (by gravity) easily. If it does, that should at least narrow down your possible problem areas. I thought I had rusted shut lines to my right rear, turned out to be a bad wheel cylinder. I did have an accumulation of gunk into that wheel cylinder that I had to use a drill bit to clean out.
It's not that I am apathetic, I just don't care. If your life is a joke, it appears death will be your punchline. |
Active Member
![]() Join Date: Jul 2007
Re: Brake help...
After you try the above (disconnecting at the T) remove the rubber brake line on the rear and check internally. You can't tell by looking at it but they collapse internally restricting fluid flow. Happened many years ago on my 69.
If it's never been replaced, I would replace all of them anyway. Cheap insurance.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Re: Brake help...
read up the factory service manual has excellent instructions on how to properly bleed the brakes
#9 | |
Re: Brake help...
Re: Brake help...
ok disconnected at the T. The fluid didnt flow with gravity but did come out after pumping the brakes. Not sure of the pressure that the fluid comes out (it was more of a steady drip/stream, wasnt spraying out. After that i tried to bleed the driver rear again and it started flowing slowly out then it stopped. The rear passenger got no flow at all.
Could it be internal in the drums or is it looking like the rubber passagways are the culprit? As i said it flowed from the T although it had to be pumped. Didnt take off the rubber line but If i can get to the auto store I'll just buy a new one as you say cheap insurance. |
Re: Brake help...
What exactly does the proportioning valve sensor do? Mines been disconnected, looks like the rubber connector melted.
#12 | |
Active Member
Re: Brake help...
I've had master cylinders new defective before. I had to return two of them once and finally told them to return my money. Went to another parts store that sold a different manufacturer brand and did not have any more problems.
#13 | |
Re: Brake help...
Defective in what way? Thinking now my rear cylinders are gunked up. Should i buy new cylinders or.... How difficult a job is it to clean up the cylinders? Do i need the wheel and adjuster parts? |
Re: Brake help...
So if the pistons are bunched together and the light's on, someone want to throw the instructions on how to reset the prop valve in here? I know it's on another thread, but sometimes having the answer at the end is nice...
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
#15 |
![]() Join Date: Sep 2005
Re: Brake help...
Hsd the same problem mine wss the rubber hose gone bad
#16 |
Re: Brake help...
I was bench bleeding mine (with tubes looped back into the reservoir rather than plugs, just the way I happen to have been taught, right or wrong.
After a while I noticed not much going on in the rearmost bore. So I think I rammed the two pistons together.
#17 | |
Active Member
Re: Brake help...
From Cardone site: 6.Using a blunt tool or dowel (brake pedal if mounted in vehicle), SLOWLY press in and release the master cylinder piston using short strokes of 3/4” to 1”. NEVER STROKE PISTON MORE THAN 1”. Repeat this step until resistance to piston movement is firm and less than 1/8”.
#18 |
Re: Brake help...
That is not a proportioning valve, it is a distribution block with a low pressure warning switch. While bleeding the brakes it is very possible for the shuttle valve in the low pressure switch to move and block off the front or rear system. To reset just open a front and a rear bleeder(at the same time) and pump the pedal, the pressure will equalize and reset the valve.. Close the bleeders and resume proper bleeding technique. Buy a suction type air bleeder, much easier then trying to bleed by depressing the pedal. Don't pump pedal fast.
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
#19 | |
Re: Brake help...
#20 |
Re: Brake help...
Ok im narrowing it down to a few problems...
1. Used plastic bench bleed nuts. The rear resevior bleeder nut (rear brakes are the issue) wont airtight seal. Noticed this after installed the MC. So I didnt get all the air out in bench bleeding. 2. When i removed the lines connected to the MC the front drips freely while the rear would not drip at all. Is my MC faulty? Is it clogged? Not sure how it would be clogged, maybe some rust got in there. The rear fluid moves when depressing the brake however thats for sure. BUT im not getting anything out of the rear bleeders. Checked the rear T and fluid came through. |
#21 |
Re: Brake help...
Used a vacuum bleeder on the rears and it got a lot of gunk and bits of rust out then nothing again. Took the bleeder nuts out to inspect and sure enough they are full of gunk and rust. Cleaned those and put them back in, vacuumed some more and still nothing.
Now I think if my rubber line wasnt collapsed before it is now after using the vacuum. Going to just change the rear line first as the fronts were ok. Might be a couple days to get the part......... |
#22 |
Re: Brake help...
Sounds like a lot of junk in your lines, should replace them.
#23 | |
Re: Brake help...
Proper brakes are cheap life insurance. Safe money elsewhere.
#24 | |
Re: Brake help...
I should also mention the rear resevior barely moved during all the latest bleeding. Wondering if my MC is bad. |
#25 |
Re: Brake help...
I'd price ship inline tube, classic tube, and the LMC-style vendors. If its not a show truck just get the cheapest mild steel ones.
I have my old set but it's a long way to Catchall.
