Old 05-30-2014, 07:28 PM   #1
Skunksmash
Skunksmash's Avatar
Full battery, wont turn over
Having some kind of starting issue. The truck won't even try to turn over. But the battery is full. 87 TBI 5.7L
What is usually the cause of this? Perhaps a dead starter? Or a dead switchkey? Do starters just up and die, or do they sound different as they get weaker and weaker?
Skunksmash is offline   Reply With Quote
Old 05-30-2014, 07:47 PM   #2
rich weyand
rich weyand's Avatar
Re: Full battery, wont turn over
Change the starter cables. They oxidize internally with no outward sign any time after ten years or so.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 05-30-2014, 08:54 PM   #3
OldCreek
OldCreek's Avatar
Check your ground (-).
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 05-30-2014, 09:31 PM   #4
franken
No click, nothing at all?
If so, the solenoid isn't starting the starter and the problem is on the low current side.
Lights? Horn?
Jump the solenoid, or measure the voltage to ground at the solenoid S terminal with the key in the start position.
What's the battery voltage?
Old 05-30-2014, 09:34 PM   #5
Kurt L
Kurt L's Avatar
i agree with rich had the same problem with a toyota one time put a new cable from the starter to the battery no more problem.
Kurt L is offline   Reply With Quote
Old 05-30-2014, 09:40 PM   #6
Hubscrub
Cruzin
Hubscrub's Avatar
give the starter a few taps with a hammer see if it moves then.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 05-31-2014, 02:05 AM   #7
Skunksmash
Skunksmash's Avatar
Yeah no click, nothing. But I have headlights and everything. I think its the switchkey, maybe. It jiggled it and tapped on it a little bit and it started working. The switchkey has been kind of worn out since I got the truck. You can take the key out while the truck is still running.
Battery voltage is fine at 13.8v
Old 05-31-2014, 07:04 AM   #8
cadillac_al
You can jump the solenoid with a screwdriver to verify that the starter has enough current and that it works.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 05-31-2014, 07:13 AM   #9
Hubscrub
Cruzin
Hubscrub's Avatar
another thought,if you have a tilt column try moving it up and down, i've have problems with mine where it wouldn't start. Not totaly sure how it all works but think there is a rod in the column that engages the ignition switch under the dash when you turn the key and wasn't doing it in certain locations.
Proverbs 3:5,6
Old 05-31-2014, 04:31 PM   #10
meter swinger
meter swinger's Avatar
You can remove the top cover from the collum and take the bottom cover off and loosen the bolts on the collum bracket until the collum drops a little. Then you can see rod on top of the collum that runs between the ign. Tumbler and the ign. Switch at the base of the collum. Turn the key and press down on the rod with needle nose pliers. If it starts your key tumbler is bad. They are cheap pot metal and have a small tang on them that breaks off.
meter swinger is offline   Reply With Quote
Old 05-31-2014, 05:11 PM   #11
rs74
rs74's Avatar
Sounds like maybe some sort of ignition issue in the column. I was originally going to say check your connections on the relay on the firewall above the distributor. I had that issue a while back. The terminals were corroded and not making contact.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 05-31-2014, 07:43 PM   #12
Skunksmash
Skunksmash's Avatar
Yeah I've been moving it around lately, maybe that has something to do with it.
But thanks for all the help everyone! I will try all of these methods to get it fixed
Old 05-31-2014, 10:41 PM   #13
franken
Battery voltage is 12.7 with a full charge so you have a magic battery I guess that's at idle...
The key on column vehicles move a rod connected to a switch down the column a bit.
Old 06-01-2014, 02:56 AM   #14
Skunksmash
Skunksmash's Avatar
The wife's toyota says 13.4v at idle and 13.8 at 2k rpm. Its not uncommon
Your battery is probably just old
Old 06-01-2014, 06:57 PM   #15
SCOTI
SCOTI's Avatar
x2.... Or not magical.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-01-2014, 09:26 PM   #16
blazerkid
blazerkid's Avatar
try hitting the bottom of the starter with a hammer
blazerkid is offline   Reply With Quote
Old 06-06-2014, 01:02 AM   #17
hatzie
Moderator
hatzie's Avatar
That's a little low. 14-14.5 is what you should see engine running.
12.7 maybe just after shutdown before it settles down to 12.2 or so.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-06-2014, 02:48 AM   #18
rich weyand
I think it's more like 13.2 volts right after shutdown. The surface charge will leak off over a dozen hours or so and settle between 12.6 and 12.7 volts for a fully charged battery.
http://en.wikipedia.org/wiki/Automot...rminal_voltage
Rich Weyand
1978 K10 RCSB DD.
Old 06-06-2014, 03:36 AM   #19
lanconcj
lanconcj's Avatar
my neutral safety switch went out on my 78 causing the same problem. At the time, it was a $5.00 part.
lanconcj is offline   Reply With Quote
Old 06-06-2014, 10:11 AM   #20
hatzie
Moderator
hatzie's Avatar
^^^ Good thing to check ^^^
Within the margin of error for my cheap shop meter.
If she settles to around 11.8-12.5 I'm happy.
Old 06-08-2014, 09:58 AM   #21
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
You can have the solenoid replaced. However, most people just opt for a new starter.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 06-08-2014, 12:03 PM   #22
Skunksmash
Skunksmash's Avatar
I kinda want to find the exact problem and fix it myself. I love turning my own wrenches whenever I can.
What exactly does it mean if you can tap the starter with a hammer, and then the problem goes away? Is that the solenoid? Could it also be something else?
And just in case, where exactly is the neutral safety switch located? I'll check it out too.
Old 06-08-2014, 01:24 PM   #23
rich weyand
Did you ever change the starter cables? They can be on and off like that.
Rich Weyand
1978 K10 RCSB DD.
Old 06-08-2014, 04:46 PM   #24
gchemist
gchemist's Avatar
The neutral safety switch is located at lower steering column inside the cab. Next time, try starting in neutral. Wiggle the shifter. If it starts or cranks, the switch is out of adjustment. It's a common problem that occurs with tilt steering. Yes, if you tap the solenoid, the kickout part is getting stuck.
Old 06-09-2014, 11:46 AM   #25
hatzie
Moderator
hatzie's Avatar
The high torque gear reduction starters off the late 90's T400 chassis trucks with smallblock engines are tiny and they will fit the older smallblock engines.
New will be Asian built and the Diesel guys have mixed results with them. Unfortunately the re-built market has been poisoned with the cheesy Chinese cores so you really need to be careful. I dug through 4 before I found an American made unit.
Hang onto your old one. It's American made so the core components are not Chinese garbage. You may want to get it re-built locally eventually.
