06-02-2014, 11:12 AM | #1 |
i.d sway bar
have 1964 c20 has sway mounted in front,when i installed lowering springs had to remove these long links that connected sway bar to l.c.a, then noticed mounts look different from what ive seen, i will try to get better pic
06-02-2014, 11:21 AM | #2 |
Re: i.d sway bar
Your mounts uses the tall end link style mounts. Should be something similar to whats in these pics
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
06-02-2014, 11:33 AM | #3 |
Re: i.d sway bar
the old ones were about 8-9 inches long figured i would just get shorter ones after drop but sway bar hits tie rod, shouldnt bar be somewhat parallel to ground
06-02-2014, 07:27 PM | #4 |
Who Me?
Re: i.d sway bar
I went thru this on my Tahoe when I lowered it and they were too long.. Once I made them shorter, they worked fine.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
06-02-2014, 08:02 PM | #5 |
Moderator
Re: i.d sway bar
Try end links for a 77-96 Caprice. I bet they'll work perfectly. I've got a couple spare Caprice bars here, I should try one out...
06-02-2014, 09:07 PM | #6 |
Re: i.d sway bar
thanks for info i will check that out, heres another pic,i was wondering why you would have to get different mounts for lowered truck when this mounts directly to frame
06-03-2014, 01:39 AM | #7 |
60-66 Nut
Re: i.d sway bar
That is not a truck sway bar. It is from a car that someone has adapted to you'r truck.
06-03-2014, 08:59 AM | #8 |
Re: i.d sway bar
so would i be better off finding another one?
06-04-2014, 01:25 AM | #9 |
60-66 Nut
Re: i.d sway bar
I would just remove that sway bar and install a truck sway bar and brackets. Most of the '73+ trucks came with sway bars. The '73+ C20's and C30's had an optional 1-1/4" diameter sway bar.
